[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo thomas.bergo at gmail.com
Wed Sep 25 06:25:50 HKT 2013
I have a Open EVSE charger at home. And it is set to 16A. But this can be
wrong, I have not measured the duty-cycle myself. Maybe I should do that
one day:-)
Matt: I can change the settings to 16A and send you a new hex file tomorrow?
Regards, Thomas
onsdag 25. september 2013 skrev Håkon Markussen følgende:
> I'm not sure what type of home charger you have Thomas, but having a 16A
> label gives no guarantee for its pilot signal to actually request 16A.
> To be 100% sure you have to read the pwm duty-cycle of the evse pilot,
> eighter by a scope or by connecting your evse to a car with available
> (known) can-message for charge current limit.
> If you have this wall mounted "pod-point" evse's, I would expect the pilot
> signal to request 16A. In that case the iMiEV-charger does overwrite the
> pilot.
> This was done on the early Think City A306 cars (gen0 PCU), which had a
> weak charger.
> Br.
> Håkon
> 2013/9/24 Thomas Bergo <thomas.bergo at gmail.com>
> The first models (2011) was delivered with a 16A cable. This was changed
> for the later models (2012 ->) to 10A cable do to firesafty.
> At home i use a 16A cable for charging, but the car only draw 13A.
> I'm not sure what is the correct info, EVSE limit or the charger limit.
> Any way the car will only draw 13A.
> The can message for current limit set by EVSE is not know for the i-Miev,
> so until this information is available we need to hardcode a value to be
> displayed in "STANDARD xxA" in the app.
> Regards, Thomas
> 2013/9/24 Håkon Markussen <hakon.markussen at gmail.com>
> Nice work Thomas,
> Your attached image reminds me that I should implement the car_time and
> car_parktime in the Think City module :-)
> Regards to max charge rate "STANDARD xxA":
> The variable car_chargelimit should contain the maximum available mains
> current, which is set by the EVSE.
> This is done in vehicle_thinkcity.c and I assume this can-message is
> available in a iMiEV and could replace the hardcoded "13A".
> The evse sends a pilot signal controlling the charger max rate, which can
> be adjusted by the user in steps depending on the evse type.
> The first evse's for iMiEV was delivered with two charging steps (maybe
> 10-16A) and got popular among Leaf-owners. Running up to 16A over the
> Schuko-connector is bad firesafety, so the later evse's were replaced with
> 13A. (I guess) limit max.
> This one is a nice one(mode 2, type 2 delivered with different charging
> connectors:
> http://salto.no/produkter/ladekabel-justerbar-13-a-type-2-shuko/
> When the max charge current is set by the evse, e.g. 13A the ac-charge
> current (which can be measured or viewed in a can-message) will never
> exceed this limit.
> Br.
>  Håkon
> I don't remember to have seen any documentation. There is a common
> understanding in Norway that the car only can drain 13A.
> I have also measured hove much current the car use when charging.
> This setting is only for information in the app, as no information is send
> to the car from the car module. There is no way that the car module can
> impact on the charge current. The voltage and current (13A) is reported by
> the car and not limited by the OVMS.
> [image: Innebygd bilde 1]
> Regards, Thomas
> 2013/9/24 Matt Beard OVMS <smvo at mxf.org.uk>
> Do you have a source for this 13A maximum claim?  Mitsubishi claim that
> the on-board charger in the iMiev runs at 240V 15A in the USA.
> If you want to use the output rating of the charger you need to reduce the
> figure to 9A as the output is 330V.
> What does the Roadster version set - does it use the input current, or
> some version of the output current?
> I notice that the Volt/Ampera code sets 16A as the charge limit.
> Matt
> On 24 September 2013 19:58, Thomas Bergo <thomas.bergo at gmail.com> wrote:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130925/6b867019/attachment.htm>
