[Ovmsdev] CAN bus noise?
Thomas Bergo
thomas.bergo at gmail.com
Mon Sep 23 17:11:22 HKT 2013
I haven't experienced any issues with traction control, but when i
disconnect the OVMS module i can hear one "click" sound form the front of
the car.
Have also read that the same is happening on the Nissan Leaf when
disconnect the CAN-Bluetooth adapter used with Leaf-Spy.
No issues, just this click when disconnecting. Does anybody else
experienced this click when disconnecting the OVMS module?
Regards, Thomas
2013/9/23 Matt Beard OVMS <smvo at mxf.org.uk>
> Except that with FEATURE_CANWRITE set to zero (as it is), the bus should
> be in listen-only mode.
> Matt
> On 23 September 2013 09:27, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
>> I have read somewhere that if you connect a bluetooth adapter with
>> "torque" app you can disable the power steering (or was it the ABS)... so I
>> would speculate that what you are experiencing is not a problem of noise,
>> but rather a problem of the software that was uploaded in the ovms. Only
>> speculation though.
>> Nikolay
>> *From:* Matt Beard <matt at beard.tv>
>> *To:* OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> *Sent:* Monday, September 23, 2013 10:12 AM
>> *Subject:* [Ovmsdev] CAN bus noise?
>> I am concerned that the OVMS v2 may be adding noise to the CAN bus, or
>> causing problems in some other way (I know very little of CAN hardware, so
>> can't really speculate much).
>> I have heard other people mention CAN errors when OVMS is connected and
>> yesterday I made my first trip with the unit connected to my C-Zero. During
>> this trip the traction control failed - something it has never done before.
>> The problem went away when the car was turned off and on again, but it
>> seems too much of a coincidence for this to be unrelated.
>> Does anyone have any opinions on this?
>> Matt Beard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130923/6e03590c/attachment.htm>
