[Ovmsdev] CAN bus noise?
Matt Beard OVMS smvo at mxf.org.uk
Mon Sep 23 16:46:44 HKT 2013
Except that with FEATURE_CANWRITE set to zero (as it is), the bus should be
in listen-only mode.
Matt
On 23 September 2013 09:27, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
> I have read somewhere that if you connect a bluetooth adapter with
> "torque" app you can disable the power steering (or was it the ABS)... so I
> would speculate that what you are experiencing is not a problem of noise,
> but rather a problem of the software that was uploaded in the ovms. Only
> speculation though.
> Nikolay
>  *From:* Matt Beard <matt at beard.tv>
> *To:* OVMS Developers <ovmsdev at lists.teslaclub.hk>
> *Sent:* Monday, September 23, 2013 10:12 AM
> *Subject:* [Ovmsdev] CAN bus noise?
> I am concerned that the OVMS v2 may be adding noise to the CAN bus, or
> causing problems in some other way (I know very little of CAN hardware, so
> can't really speculate much).
> I have heard other people mention CAN errors when OVMS is connected and
> yesterday I made my first trip with the unit connected to my C-Zero. During
> this trip the traction control failed - something it has never done before.
> The problem went away when the car was turned off and on again, but it
> seems too much of a coincidence for this to be unrelated.
> Does anyone have any opinions on this?
> Matt Beard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130923/ba69c690/attachment.htm>
