[Ovmsdev] Client side APIs
Tue Oct 15 12:53:40 HKT 2013
> - is there an http API for apps, or is there one planned?
Kind of. We have one in development, and a prototype running live. I just need to get the authentication framework better (probably based on oauth) before formal release. I've attached the eMail (from earlier this year) to this message, below.
> - is there a simulator or dump of test messages which would allow someone (me!) who has no car or OVMS equipment to still develop apps etc against the API?
We have two live demo cars which produce data you can use. VehicleID/Password are DEMO/DEMO and RALLY/RALLY. These should both be live on the tmc server.
> - has anyone done any work on communicating with OVMS using JavaScript?
Not that I know of.
Fwd: [Ovmsdev] HTTP API
I've done some work on this, and tidied up the foundational servers. I've now got a basic framework working in the non-blocking environment of ovms_server.pl.
You can try this yourself using http://tmc.openvehicles.com/api. At the moment I've only enabled HTTP. I'll enable HTTPS (the server already supports it - I just need to install the certificates) when we are ready for production.
The first thing you must do to use the api is authenticate to establish a session and get a cookie (so you don't need to authenticate every time). This is done with a http "GET /api/cookie" passing parameters 'username' and 'password' as your www.openvehicles.com username and password respectively.
$ curl -v -X GET -c cookiejar http://tmc.openvehicles.com:6868/api/cookie?username=USERNAME\&password=PASSWORD
* About to connect() to tmc.openvehicles.com port 6868 (#0)
*   Trying 64.111.70.40...
* connected
* Connected to tmc.openvehicles.com (64.111.70.40) port 6868 (#0)
> GET /api/cookie?username=USERNAME&password=PASSWORD HTTP/1.1
> User-Agent: curl/7.24.0 (x86_64-apple-darwin12.0) libcurl/7.24.0 OpenSSL/0.9.8r zlib/1.2.5
> Host: tmc.openvehicles.com:6868
> Accept: */*
* HTTP 1.0, assume close after body
< HTTP/1.0 200 Authentication ok
< Connection: close
< Content-Length: 9
< Cache-Control: max-age=0
< Content-Type: text/plain
* Added cookie ovmsapisession="9ed66d0e-5768-414e-b06d-476f13be40ff" for domain tmc.openvehicles.com, path /api/, expire 0
< Set-Cookie: ovmsapisession=9ed66d0e-5768-414e-b06d-476f13be40ff
< Date: Fri, 22 Feb 2013 12:43:56 GMT
< Expires: Fri, 22 Feb 2013 12:43:56 GMT
Login ok
Once logged in, all subsequent requests should pass the cookie (ovmsapisession). The session will expire after 3 minutes of no use, or you can specifically terminate / logout the session by calling "DELETE /api/cookie".
We could have other authentication mechanisms, but I'm really trying to move to a simple username/password mechanism.
To obtain a list of vehicles on your account, you can use the "GET /api/vehicles" call:
$ curl -v -X GET -b cookiejar http://tmc.openvehicles.com:6868/api/vehicles
* connected
> GET /api/vehicles HTTP/1.1
> Accept: */*
< HTTP/1.0 200 Logout ok
< Connection: close
< Content-Length: 280
< Content-Type: application/json
< Date: Fri, 22 Feb 2013 12:44:41 GMT
< Expires: Fri, 22 Feb 2013 12:44:41 GMT
  {"id":"DEMO","v_apps_connected":0,"v_net_connected":1},
  {"id":"MARKSCAR","v_apps_connected":1,"v_net_connected":1},
  {"id":"QCCAR","v_apps_connected":0,"v_net_connected":0},
  {"id":"RALLYCAR","v_apps_connected":0,"v_net_connected":0},
  {"id":"TESTCAR","v_apps_connected":0,"v_net_connected":0}
(note that the above is re-formatted slightly, to make it clearer to read).
The return data is a json formatted array of hashes. Each record is one for one vehicle and shows you the vehicle id, as well as counts for the number of apps currently connected to that vehicle, and whether the vehicle is connected to the net (server) or not.
From the server point of view, we can treat an api session just like an app session. From the vehicle point of view there will be no difference - once an API connects to a vehicle, the server will send a "Z 1" message to tell the module it has a connection. If the session times out or is logged out, the server will inform the modules in the vehicles.
The above has all been implemented, and you can try it.
The following commands are what I am thinking about:
GET	/api/protocol/<VEHICLEID>		Return raw protocol records (no vehicle connection)
GET	/api/vehicle/<VEHICLEID>		Connect to, and return vehicle information
DELETE	/api/vehicle/<VEHICLEID>		Disconnect from vehicle
GET	/api/status/<VEHICLEID>			Return vehicle status
GET	/api/tpms/<VEHICLEID>			Return toms status
GET	/api/location/<VEHICLEID>		Return vehicle location
GET	/api/charge/<VEHICLEID>			Return vehicle charge status
PUT	/api/charge/<VEHICLEID>			Set vehicle charge status
DELETE	/api/charge/<VEHICLEID>			Abort a vehicle charge
GET	/api/lock/<VEHICLEID>			Return vehicle lock status
PUT	/api/lock/<VEHICLEID>			Lock a vehicle
DELETE	/api/lock/<VEHICLEID>			Unlock a vehicle
GET	/api/valet/<VEHICLEID>			Return valet status
PUT	/api/valet/<VEHICLEID>			Enable valet mode
DELETE	/api/valet/<VEHICLEID>			Disable valet mode
GET	/api/features/<VEHICLEID>		Return vehicle features
PUT	/api/feature/<VEHICLEID>		Set a vehicle feature
GET	/api/parameters/<VEHICLEID>		Return vehicle parameters
PUT	/api/parameter/<VEHICLEID>		Set a vehicle parameter
PUT	/api/reset/<VEHICLEID>			Reset the module in a particular vehicle
PUT	/api/homelink/<VEHICLEID>		Activate home link
GET	/api/historical/<VEHICLEID>		Request historical data summary
GET	/api/historical/<VEHICLEID>/<DATATYPE>	Request historical data records
Thoughts / suggestions?
Begin forwarded message:
> Subject: [Ovmsdev] HTTP API
> Date: 18 February, 2013 9:41:15 AM HKT
> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
> For some time now I've wanted to offer an HTTP API for OVMS. The existing car<->server and server<->app protocol is cool, but requires going through some hoops (perl, whatever) to handle the encryption and protocol level stuff. An HTTP API would make this much easier to externally script, and would be great for pulling down logs and other such things.
> I've now completed work re-factoring the ovms_server.pl code to add the framework to support this:
> Switched to using the AnyEvent::HTTPD cpan module for the base framework.
> Implemented an HTTP server on tcp/6868.
> Implemented an HTTPS server on tcp/6869.
> Support serving of arbitrary files (in httpfiles directory) for HTTP and HTTPS.
> Implemented syncing of Drupal user accounts (and password hashes) to new ovms_owners table.
> Extended the protocol to support syncing owners and well as vehicle records.
> Support syncing ovms_owners table to connected OVMS servers.
> Moved ovms_utilisation to ovms_historicalmessages as type '*-OVM-Utilisation", with records 0 (car_rx), 1 (car_tx), 2 (app_rx) and 3 (app_tx).
> The above work has just been PUSHed to github.
> So, the framework exists. Now for the fun stuff.
> My thinking is:
> Authenticate to a vehicle either by vehicle + serverpass, or OVMS username+password.
> You can get a list of vehicles by providing your OVMS username+password.
> Use cookies to maintain a session - and time sessions out after a few minutes of inactivity (or on demand logout).
> Basic functions to retrieve current vehicle status, and historical data.
> Function to 'connect' to a live vehicle - just like an App, it will keep the connection open for as long as the session lasts, then tell the vehicle you have disconnected.
> Control functions - just like the apps - start/stop charge, homelink, etc.
> Support for OVMS protocol, so can convert the data messages to actual real-world JSON.
> Does anyone want to work with me on this? In particular, anyone with RESTful or other HTTP API experience?
On 15 Oct, 2013, at 12:23 pm, Christopher Cook <christopher.cook at webprofusion.com> wrote:
> Hi Mark,
> couple of questions you can probably help with:
> I'm interested from a cross platform app point of view, as I'm sure your aware it can get rather laborious trying to develop 3 or more versions of an app natively and performance-wise there's probably no specific reason for an OVMS compatible app to be native (C#, Java, Obj-C etc). Incidentally have you seen the MonoTouch etc frameworks- could also be a way to consolidate app code across platforms?
> Thanks for any info/thoughts.
> Chris
> Sent from my iPad_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131015/935bcf95/attachment.htm>
