[Ovmsdev] How to remove temperatures from app?
Mon Oct 28 18:56:19 HKT 2013
Should be light gray if they are stale, bright white if ok.
> On 28 Oct, 2013, at 5:55 pm, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Mark,
> The code is implemented as your example, so the temperatures will be indicated as stale by the code.
> Is there a visual indication in the app to show that the temperature are updated or stale? Now the app show the last temperature before the car was parked/stop charging.
> Regards, Thomas
> 2013/10/24 Mark Webb-Johnson <mark at webb-johnson.net>
>> Matt,
>>> In the iMiev, the CAN bus stops when the car is parked and not charging, which means that the temperatures go stale.
>>> I want to flag this to the app, but I'm not sure how to do that. I assumed that setting them back to their "default" state would return the app to displaying "-"
>> Use:
>> ovms.{h,c}:
>> signed char car_stale_ambient; // 0 = Ambient temperature is stale
>> signed char car_stale_temps; // 0 = Powertrain temperatures are stale
>> Most common method is that every time you receive a CAN bus message with the temps (motor, pem, battery), set car_stale_temps=60 (or car_stale_ambient=60 for ambient).
>> Then, in your one-second-ticker function, just:
>> if (car_stale_ambient>0) car_stale_ambient--;
>> if (car_stale_temps>0) car_stale_temps--;
>> That will automatically signal them as stale after 60 seconds of no update.
>>> P.S. Now we have iMiev support (although a bit beta) and are about to get Leaf support - when do we get these car picture in the app? ;-)
>> Can you hold a few weeks for this? I am working on the Apps to re-work how we do the vehicle images. They are just too large (13MB+ already!), so I am working on a better way of handling the multiple colours and making it easier to add them to the Apps. Once I have this working, I'll let you know what format we need the images in.
>>> This doesn't seem to work. Should it?
>>> Matt Beard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20131028/71fdafd1/attachment.html>
