[Ovmsdev] How to remove temperatures from app?
Thomas Bergo
thomas.bergo at gmail.com
Mon Oct 28 17:55:22 HKT 2013
Mark,
The code is implemented as your example, so the temperatures will be
indicated as stale by the code.
Is there a visual indication in the app to show that the temperature are
updated or stale? Now the app show the last temperature before the car was
parked/stop charging.
Regards, Thomas
2013/10/24 Mark Webb-Johnson <mark at webb-johnson.net>
> Matt,
> In the iMiev, the CAN bus stops when the car is parked and not charging,
> which means that the temperatures go stale.
> I want to flag this to the app, but I'm not sure how to do that. I assumed
> that setting them back to their "default" state would return the app to
> displaying "-"
> Use:
> ovms.{h,c}:
> signed char car_stale_ambient; // 0 = Ambient temperature is stale
> signed char car_stale_temps; // 0 = Powertrain temperatures are stale
> Most common method is that every time you receive a CAN bus message with
> the temps (motor, pem, battery), set car_stale_temps=60 (or
> car_stale_ambient=60 for ambient).
> Then, in your one-second-ticker function, just:
> if (car_stale_ambient>0) car_stale_ambient--;
> if (car_stale_temps>0) car_stale_temps--;
> That will automatically signal them as stale after 60 seconds of no update.
> P.S. Now we have iMiev support (although a bit beta) and are about to get
> Leaf support - when do we get these car picture in the app? ;-)
> Can you hold a few weeks for this? I am working on the Apps to re-work how
> we do the vehicle images. They are just too large (13MB+ already!), so I am
> working on a better way of handling the multiple colours and making it
> easier to add them to the Apps. Once I have this working, I'll let you know
> what format we need the images in.
> displaying "-"
> This doesn't seem to work. Should it?
> Matt Beard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20131028/ddd72745/attachment.html>
