[Ovmsdev] v2.5.4 call for testing
Jack West jackduncanwest at gmail.com
Wed Oct 16 12:34:57 HKT 2013
A little more background.
OVMS V2 TR2.5. The car is in the city with typically great reception, but it is parked in a parking garage, on the outside edge with a view.
The app did show that the car was charging in range mode so that part works.  Just the SMS report was wrong.
It is interesting that I got the ACC #0 (not a typo) no ACC defined here- as I thought the ACC's are 1-4.  Perhaps I caused some bug to occur by trying to set the ACC PARAMS before the car was at the location and the ACC HERE was issued.  I did have some unexpected responses after that.  If you think that might be relevant I could send the transcript of commands I used and OVMS' response.
To follow up on the CHARGEBY command, I think the charge finished about two hours early.  I'm not positive I have the time set correctly and so I will look into that.
All in all I'd have to say you ROCK!  The charge to 50% was the perfect solution to the short commute but still want to plug in scenario.
Jack
On Oct 15, 2013, at 5:48 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Jack,
> Seems to be a bug in display of RANGE mode for ACC. I need to check what the mode number should be (as setting mode uses 0,1,3,4 but displaying mode uses 0,1,2,3 - which is why your range mode is being shown as performance).
> I think the mode set is the correct one, and even though it says 'performance' it will actually be a range mode charge.
> I'm not sure why your first 'ACC PARAMS' command did not find the location. The code looks ok and works for me. Maybe the GPS location is not locked or off by too much from the ACC location (car in a garage?).
> On 16 Oct, 2013, at 1:11 am, Jack West <jackduncanwest at gmail.com> wrote:
>> I've been trying this a bit.
>> Me-ACC HERE
>> OVMS-ACC #2 set
>> Me-ACC PARAMS CHARGEBY 16:30 MODE RAN LIMIT 48
>> OVMS-ACC #0 - No ACC defined here
>> Me-ACC ENABLE 2
>> OVMS-ACC enabled
>> Me-ACC PARAMS 2
>> OVMS-ACC#2 (lat/long) Enabled Mode:standard(0A)
>> Me-ACC PARAMS 2 MODE RAN LIMIT 48 CHARGEBY 16:30
>> OVMS-ACC#2 (lat/long) Enabled Charge by time 16:30:00 Mode:performance (48A)
>> Me-ACC PARAMS 2 MODE RANGE
>> (No response)
>> Me-ACC PARAMS?
>> OVMS-ACC#2 (lat/long) Enabled Charge by time 16:30:00 Mode: performance (48A)
>> The iPhone app shows the car charging in range mode at 48 amps.
>> Jack
