[Ovmsdev] v2.5.4 call for testing
Wed Oct 16 09:48:05 HKT 2013
Jack,
Seems to be a bug in display of RANGE mode for ACC. I need to check what the mode number should be (as setting mode uses 0,1,3,4 but displaying mode uses 0,1,2,3 - which is why your range mode is being shown as performance).
I think the mode set is the correct one, and even though it says 'performance' it will actually be a range mode charge.
I'm not sure why your first 'ACC PARAMS' command did not find the location. The code looks ok and works for me. Maybe the GPS location is not locked or off by too much from the ACC location (car in a garage?).
On 16 Oct, 2013, at 1:11 am, Jack West <jackduncanwest at gmail.com> wrote:
> I've been trying this a bit.
> Me-ACC HERE
> OVMS-ACC #2 set
> Me-ACC PARAMS CHARGEBY 16:30 MODE RAN LIMIT 48
> OVMS-ACC #0 - No ACC defined here
> Me-ACC ENABLE 2
> OVMS-ACC enabled
> Me-ACC PARAMS 2
> OVMS-ACC#2 (lat/long) Enabled Mode:standard(0A)
> Me-ACC PARAMS 2 MODE RAN LIMIT 48 CHARGEBY 16:30
> OVMS-ACC#2 (lat/long) Enabled Charge by time 16:30:00 Mode:performance (48A)
> Me-ACC PARAMS 2 MODE RANGE
> (No response)
> Me-ACC PARAMS?
> OVMS-ACC#2 (lat/long) Enabled Charge by time 16:30:00 Mode: performance (48A)
> The iPhone app shows the car charging in range mode at 48 amps.
> Jack
