[Ovmsdev] Debug vs Normal messages in Tesla Roadster
Tue Nov 5 08:38:29 HKT 2013
My recent message says "Debug Text" but I assume that's just because I have
the VDS in debug mode, thus I¹m seeing the debug version of the text, but I
would see the message even if the VDS was in user mode. I would hope I¹d see
that message since it prevented a charge from completing.
"Debug-Only Msg" presumably means the message only appears in debug mode.
Are all of those messages prefixed by "DMC"? Is that where that term comes
from?
   Tom
From:  Mark Webb-Johnson <mark at webb-johnson.net>
Reply-To:  OVMS Developers <ovmsdev at lists.teslaclub.hk>
Date:  Monday, November 4, 2013 at 5:46 PM
Subject:  Re: [Ovmsdev] Debug vs Normal messages in Tesla Roadster
Tom,
Yep. I feel there are some big gaps in our understanding of debug messages.
>From Pierre's post yesterday, it also seems that we have 'Debug Text' and
'Debug-Only Msg' in blue, in the top left corner of the message.
I hadn't noticed that before.
I think the only way I am going to be able to work this out is to try to
spoof some messages to the car and see what comes up on the VDS.
On 5 Nov, 2013, at 7:31 am, Tom Saxton <tom at idleloop.com> wrote:
> I looked at all of the data and assumed that all messages that had text but
> aren't marked as DMC are not debug messages. I ignored messages that had no
> text.
> The DMC messages have no bits in common. Together, they use the bits in
> 0x08293200.
> The user messages also have not bits in common. Together, they use the bits in
> 0xC5BFBFFF.
> Because neither class of messages all share a bit, there is no single bit in
> the data field that marks an error as either debug or user.
> The bits in 0x00293200 appear in at least one debug message and at least one
> user message. Therefore, none of those bits can distinguish one from the
> other.
> The bits in 0x00293200 appear in at least one user message, but no debug
> messages. Maybe there¹s something useful there...
> Unfortunately, there are several messages whose only set data bits also appear
> in debug messages. For example these two messages have the same data value,
> but one is debug and one is not.
>   954 00000000001000000000000000000000 00200000      2097152 Line Voltage Lost
> Sync
>  1146 00000000001000000000000000000000 00200000      2097152 DMC Motor Fan
> Problem
> Therefore, the data value cannot be used to distinguish debug messages from
> user messages.
> Bummer.
>    Tom
> Date:  Sunday, November 3, 2013 at 5:14 PM
> Subject:  [Ovmsdev] Debug vs Normal messages in Tesla Roadster
> I'm not having much luck trying to differentiate between debug and normal
> alert messages in the Tesla Roadster. So, here is my working so far, and
> calling out for ideas.
> First, here is what is known about the CAN bus message relating to this:
>>         Error Notification
>>                 ID=0x100
>>                 B1=0x93
>>                 B2=On, Off, Severity, etc, indication
>>                 B3=Error code LSB
>>                 B4=Error code MSB (error code 0xFFFF means no error)
>>                 B5=Data LSB
>>                 B6=Data
>>                 B7=Data
>>                 B8=Data MSB
>>                 N.B. Regarding B2, we've seen:
>>                         0x01 = 00000001b = Show Alert
>>                         0x00 = 00000000b = Cancel Alert
>>                         0x05 = 00000101b = Show Alert
>>                         0x04 = 00000100b = Cancel Alert
>>                         0x15 = 00010101b = Show Message
>>                         0x14 = 00010100b = End Message
>>                      Suggestion is that bit0 is set when alert is raised, and
>> zeroed when alert is cleared.
> Here is some raw can bus messages showing some alerts coming and going:
>>          6.6947 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>         13.4250 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         20.1151 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         26.8368 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         33.5484 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         40.2862 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         46.9766 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         53.6772 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         60.3577 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
>>         63.2089 100 93 04 78 03 00 00 00 00    ->VDS (message to VDS 93)
>>         67.0663 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>         73.7502 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>         80.2421 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>         80.4511 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>         87.1387 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>         93.8198 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        100.5295 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        107.2297 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        113.9373 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        120.6307 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        121.7428 100 93 04 8D 04 20 00 00 00    ->VDS (message to VDS 93)
>>        127.3396 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        128.3633 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        134.0215 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        140.7018 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        147.4018 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        147.9951 100 93 04 91 04 00 02 00 00    ->VDS (message to VDS 93)
>>        154.1413 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        160.8654 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        167.5743 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        174.5784 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        181.3024 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        188.0697 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        194.7832 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
>>        201.4736 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
> The message shown on the car's VDS includes 4 bytes of data, so we are
> assuming that is B5..B8.
> The most likely seemed to be B2, which we don't normally report back to the
> server. So, I switched my car to report that rather that the Data (B5..B8) and
> here is what I got:
>> rx msg P ETR2N,1165,5
>> rx msg P ETR2N,888,5
>> rx msg P ETR2N,1124,5
>> rx msg P ETR2N,1166,5
>> rx msg P ETR2N,1146,5
>> rx msg P ETR2N,954,1
> 1146 (DMC Motor Fan Problem) is a debug message. 954 (line voltage lost sync),
> 1166 (release parking brake), 888 (disarm vehicle with keyfob), 1165 (door
> ajar) and 1124 (unsafe gear shift) are not. The last number (5 or 1) is the B2
> value corresponding to the alert. I have no idea why 954 should be B2=1 and
> the others B2=5, but it seems to have no relation to the debug level of the
> alert.
> So, how about the ID number of the alert itself? Well, here is the list of
> known alerts, with the ID number shown in binary, hexadecimal and decimal,
> followed by the message:
>> 0000000000011001 0019    25 Memory Stick transfer in progress (%d%%)
>> 0000000000110101 0035    53 GPS: No data fault
>> 0000000100001101 010d   269 BSM: Negative contactor/economizer stuck low
>> 0000000100011011 011b   283 BSM: Isolation fault
>> 0000000100011110 011e   286 BSM: Isolation fault while contactors closed
>> 0000000100011111 011f   287 Power train Problem Service Required
>> 0000000110011001 0199   409 TPMS: Hardware Error
>> 0000000110101100 01ac   428 12V Battery Service Required
>> 0000001001011100 025c   604 Battery Low Power Reduced
>> 0000001001011110 025e   606 ESS: Range Mode Remaining charge uncertain
>> 0000001001100011 0263   611 ESS: Almost empty - Car stops in 1 mile
>> 0000001101110010 0372   882 Before starting, charge port door must be closed
>> 0000001101111000 0378   888 Disarm vehicle with key fob before starting
>> 0000001110100110 03a6   934 DMC FW: Line OverCurrent Peak Fault
>> 0000001110101000 03a8   936 Charging Problem
>> 0000001110101001 03a9   937 Charge Problem Extension Cord Detected
>> 0000001110110001 03b1   945 System too hot - Vehicle shutting down
>> 0000001110111001 03b9   953 Line Voltage Lost Sync
>> 0000001110111010 03ba   954 Line Voltage Lost Sync
>> 0000001111001110 03ce   974 DMC FW: Pole Current Error Fault
>> 0000001111010101 03d5   981 DMC FW: Bad State Transition Fault
>> 0000001111000000 03c0   960 DMC FW: VBrickMax versus VBattery Error fault
>> 0000010000110001 0431  1073 DMC FW: PhaseA OverTemp warning. Torque limited
>> 0000010000110010 0432  1074 DMC FW: PhaseA Temp Diff warning
>> 0000010000110110 0436  1078 DMC FW: PhaseC Temp Diff warning
>> 0000010000111100 043c  1084 External Charger Problem
>> 0000010001000100 0444  1092 Do not plug in charge cable while driving
>> 0000010001001111 044f  1103 ABS & Traction Control Problems. Service
>> Required.
>> 0000010001100100 0464  1124 Unsafe Gear Shift Transition Denied
>> 0000010001111000 0478  1144 Powertrain Problem Service Required
>> 0000010001111010 047a  1146 DMC Motor Fan Problem
>> 0000010010000000 0480  1152 DMC WARNING Charge Thermal Limit
>> 0000010010001101 048d  1165 Key in Key Switch Door Ajar
>> 0000010010001110 048e  1166 Release Parking Brake
>> 0000010010010001 0491  1169 Charge port open
>> 0000010010010010 0492  1170 Tow Mode is not available while car is on
>> 0000010010010110 0496  1174 Fasten Seatbelt
>> 0000010110001000 0588  1416 Low Power System Service Required
>> 0000010110110111 05b7  1463 HVAC: Compressor OverTemp
>> 0000010110111001 05b9  1465 HVAC: Low current pump fault
>> 0000010110111101 05bd  1469 HVAC: Compressor comms timeout
>> 0000010110111111 05bf  1471 HVAC: Compressor DTC comms timeout
>> 0000100000011110 081e  2078 There was a problem processing your request
> The "DMC" prefix is supposed to indicate a debug message. I don't see any
> pattern. It has also been reported that one single ID can have both debug and
> non-debug variants to the message - see:
> http://www.teslamotorsclub.com/showwiki.php?title=Roadster
> So, here is all the error codes and data that we've seen for the past few
> months (error code, followed by data bytes in binary, hex and decimal):
>>     0 00000000000000000000000000000000 00000000            0
>>     3 00000000000000000000000000000000 00000000            0
>>     3 00000000000000000000000000000100 00000004            4
>>     3 00000000000000000000000000100000 00000020           32
>>     3 00000000001000000000000000000000 00200000      2097152
>>     3 10000001001000100011100010110100 812238b4   2166503604
>>     3 10000001001010111011100010110100 812bb8b4   2167126196
>>     3 10000001001011001011100010110100 812cb8b4   2167191732
>>    10 00000000000000000000000000010000 00000010           16
>>    10 00000000000000000000000000100000 00000020           32
>>    10 00000000000000000000100000000000 00000800         2048
>>    10 01000000000000000000000000000100 40000004   1073741828
>>    19 00000000000000000000000000000000 00000000            0
>>    25 00000000000000000000000000000000 00000000            0 Memory Stick
>>    25 00000000000000000000000000000001 00000001            1 Memory Stick
>>    25 00000000000000000000000000000010 00000002            2 Memory Stick
>>    25 00000000000000000000000000000011 00000003            3 Memory Stick
>>    25 00000000000000000000000000101111 0000002f           47 Memory Stick
>>    25 00000000000000000000000000110000 00000030           48 Memory Stick
>>    25 00000000000000000000000001000000 00000040           64 Memory Stick
>>    25 00000000000000000000000001000001 00000041           65 Memory Stick
>>    25 00000000000000000000000001000010 00000042           66 Memory Stick
>>    25 00000000000000000000000001100001 00000061           97 Memory Stick
>>    25 00000000000000000000000001100011 00000063           99 Memory Stick
>>    25 00000000000000000000000001100100 00000064          100 Memory Stick
>>    29 00000000000000000000000000000000 00000000            0
>>    32 00000000000000000000000000000010 00000002            2
>>    50 00000000000000000000000000000000 00000000            0
>>    52 00000000000000000000000000000100 00000004            4
>>    53 00000000000000000000000000000000 00000000            0
>>    53 00000000000000000000000000001000 00000008            8
>>    55 00000000000000000000000000100000 00000020           32
>>    57 00000000000000000000000000000000 00000000            0
>>    57 00000000000000000000000010000000 00000080          128
>>    63 00000000000000000010000000000000 00002000         8192
>>   104 00000000000000000100000000000000 00004000        16384
>>   257 00000000000000000000000000000001 00000001            1
>>   263 00000000000000000000000001000000 00000040           64
>>   264 00000000000000000000000010000000 00000080          128
>>   269 00000000000000000001010000000000 00001400         5120 BSM: Negative
>>   270 00000000000000000010100000000000 00002800        10240
>>   271 00000000000000000100000000000000 00004000        16384
>>   276 00000000000010000000000000000000 00080000       524288
>>   283 00100100000000000000000000000000 24000000    603979776
>>   283 01000100000000000000000000000000 44000000   1140850688
>>   286 00100100000000000000000000000000 24000000    603979776
>>   287 01000100000000000000000000000000 44000000   1140850688 Power train
>>   399 00010000000000000000000000000000 10000000    268435456
>>   399 10000001001000100011100010110100 812238b4   2166503604
>>   399 10000001001000111011100010110100 8123b8b4   2166601908
>>   399 10000001001010111011100010110100 812bb8b4   2167126196
>>   399 10000010111110011011100010110100 82f9b8b4   2197403828
>>   400 00000000000000000000000000000100 00000004            4
>>   400 00000000000000000000000100000000 00000100          256
>>   400 00010000000000000000000000000000 10000000    268435456
>>   400 10000001001000100011100010110100 812238b4   2166503604
>>   400 10000001001000110011100010110100 812338b4   2166569140
>>   400 10000001001000111011100010110100 8123b8b4   2166601908
>>   400 10000001001010111011100010110100 812bb8b4   2167126196
>>   400 10000010111110011011100010110100 82f9b8b4   2197403828
>>   401 00000000000000000000000000000001 00000001            1
>>   403 00000000000000000000000000000100 00000004            4
>>   405 00000000000000000000000000010000 00000010           16
>>   407 00000000000000000000000001000000 00000040           64
>>   409 00000000000000000000000100000000 00000100          256 TPMS: Hardware
>> Error
>>   415 00000000000000000100000000000000 00004000        16384
>>   416 00000000000000001100000000000000 0000c000        49152
>>   420 00000000000000000000000000000001 00000001            1
>>   428 00000000000000000000000000000000 00000000            0 12V Battery
>> Service Required
>>   428 00000000000000000000000000000001 00000001            1 12V Battery
>> Service Required
>>   428 00000000000000000000000000000100 00000004            4 12V Battery
>> Service Required
>>   428 00000000000000000000000000010000 00000010           16 12V Battery
>> Service Required
>>   428 00000000000000000000000000100000 00000020           32 12V Battery
>> Service Required
>>   428 00000000000000000000000001000000 00000040           64 12V Battery
>> Service Required
>>   428 00000000000000000000000010000000 00000080          128 12V Battery
>> Service Required
>>   428 00000000000000000000000100000000 00000100          256 12V Battery
>> Service Required
>>   428 10000001001000011011100010110100 8121b8b4   2166470836 12V Battery
>> Service Required
>>   428 10000001001000011011110110011100 8121bd9c   2166472092 12V Battery
>> Service Required
>>   428 10000001001000100011100010110000 812238b0   2166503600 12V Battery
>> Service Required
>>   428 10000001001000100011100010110100 812238b4   2166503604 12V Battery
>> Service Required
>>   428 10000001001000100011110110011100 81223d9c   2166504860 12V Battery
>> Service Required
>>   428 10000001001001000011100010110100 812438b4   2166634676 12V Battery
>> Service Required
>>   428 10000001001001000011110110011100 81243d9c   2166635932 12V Battery
>> Service Required
>>   428 10000001001010111011100010110100 812bb8b4   2167126196 12V Battery
>> Service Required
>>   428 10000001001010111011110110011100 812bbd9c   2167127452 12V Battery
>> Service Required
>>   529 00000000000000000000000000000000 00000000            0
>>   529 00000000000000000000000000000100 00000004            4
>>   529 00000000000000000000000000001000 00000008            8
>>   529 00000000000000000000000000001100 0000000c           12
>>   529 00000000000000000000000000100000 00000020           32
>>   529 00000000000000000000000100000000 00000100          256
>>   529 00000000000000000000000100000100 00000104          260
>>   529 00000100000000000000000000000000 04000000     67108864
>>   529 00010000000000000000000000000000 10000000    268435456
>>   529 00100100000000000000000000000000 24000000    603979776
>>   529 01000000000000000000000000000100 40000004   1073741828
>>   529 01000000000000000000000000001100 4000000c   1073741836
>>   529 10000001001000100011100010110100 812238b4   2166503604
>>   529 10000001001001001011100010110100 8124b8b4   2166667444
>>   530 10000001001010111011100010110100 812bb8b4   2167126196
>>   537 00000000000000000010000000000000 00002000         8192
>>   537 00010000000000000000000000000000 10000000    268435456
>>   537 10000001001000100011100010110100 812238b4   2166503604
>>   537 10000001001000111011100010110100 8123b8b4   2166601908
>>   538 10000001001000100011100010110100 812238b4   2166503604
>>   538 10000001001000100011110110011100 81223d9c   2166504860
>>   539 00010000000000000000000000000000 10000000    268435456
>>   539 10000001001011000011100010110100 812c38b4   2167158964
>>   539 10000001001011000011110110011100 812c3d9c   2167160220
>>   601 00000000000000000000000000000010 00000002            2
>>   604 00000000000000000000000000010000 00000010           16 Battery Low
>> Power Reduced
>>   604 00000000000000000000000000010010 00000012           18 Battery Low
>> Power Reduced
>>   606 00000000000000000000000001000000 00000040           64
>>   608 00000000000000000000000100000000 00000100          256
>>   609 00000000000000000000001000000000 00000200          512
>>   610 00000000000000000000010000000000 00000400         1024
>>   611 00000000000000000000100000000000 00000800         2048
>>   881 00000000000000000000000000000010 00000002            2
>>   882 00000000000000000000000000000100 00000004            4 Before starting,
>>   883 00000000000000000000000000001000 00000008            8
>>   887 00000000000000000000000010000000 00000080          128
>>   888 00000000000000000000000100000000 00000100          256 Disarm vehicle
>>   888 00000000000000000000000100000100 00000104          260 Disarm vehicle
>>   920 00000000000010000000000000000000 00080000       524288
>>   925 00000000000000000000000100000000 00000100          256
>>   925 00000001000000000000000000000000 01000000     16777216
>>   934 00000000000000000000000000000010 00000002            2
>>   935 00000000000000000000000000000100 00000004            4
>>   936 00000000000000000000000000001000 00000008            8 Charging Problem
>>   936 00000000000000000000000000001010 0000000a           10 Charging Problem
>>   937 00000000000000000000000000010000 00000010           16 Charge Problem
>>   945 00000000000000000001000000000000 00001000         4096
>>   953 00000000000000000000000000000000 00000000            0 Line Voltage
>> Lost Sync
>>   953 00000000000100000000000000000000 00100000      1048576 Line Voltage
>> Lost Sync
>> Lost Sync
>>   955 00000000010000000000000000000000 00400000      4194304
>>   974 00000000000000000000001000000000 00000200          512 DMC FW: Pole
>> Current Error Fault
>>   977 00000000000000000001000000000000 00001000         4096
>>   981 00000000000000010000000000000000 00010000        65536 DMC FW: Bad
>>  1022 00000010000000000000000000000000 02000000     33554432
>>  1023 00000100000000000000000000000000 04000000     67108864
>>  1023 00000110000000000000000000000000 06000000    100663296
>>  1063 00000000000000000000000000000100 00000004            4
>>  1065 00000000000000000000000000010000 00000010           16
>>  1067 00000000000000000000000001000000 00000040           64
>>  1069 00000000000000000000000100000000 00000100          256
>>  1070 00000000000000000000001000000000 00000200          512
>>  1070 00000000000000000000001100000000 00000300          768
>>  1073 00000000000000000001000000000000 00001000         4096 DMC FW: PhaseA
>>  1074 00000000000000000010000000000000 00002000         8192 DMC FW: PhaseA
>> Temp Diff warning
>>  1076 00000000000000001000000000000000 00008000        32768
>>  1077 00000000000000010000000000000000 00010000        65536
>>  1077 00000000000000011000000000000000 00018000        98304
>>  1081 00000000000100000000000000000000 00100000      1048576
>>  1082 00000000001000000000000000000000 00200000      2097152
>>  1084 00000000100000000000000000000000 00800000      8388608 External Charger
>> Problem
>>  1084 00000000100000000000000000010000 00800010      8388624 External Charger
>> Problem
>>  1085 00000001000000000000000001000000 01000040     16777280
>>  1086 00000010000000000000000000000000 02000000     33554432
>>  1087 00000100000000000000000000000000 04000000     67108864
>>  1092 10000000000000000000000000000000 80000000   2147483648 Do not plug in
>>  1094 00000000000000000000000000000010 00000002            2
>>  1095 00000000000000000000000000000100 00000004            4
>>  1096 00000000000000000000000000000000 00000000            0
>>  1096 00000000000000000000000000001000 00000008            8
>>  1103 00000000000000000000010000000000 00000400         1024 ABS & Traction
>> Control Problems. Service Required.
>>  1124 10000000000000000000000000000000 80000000   2147483648 Unsafe Gear
>>  1131 00000000000000000000000001000000 00000040           64
>>  1133 00000000000000000000000100000000 00000100          256
>>  1144 00000000000010000000000000000000 00080000       524288 Powertrain
>> Problem
>>  1146 00001000001000000000000000000000 08200000    136314880 DMC Motor Fan
>> Problem
>>  1152 00001000000000000000000000000000 08000000    134217728 DMC WARNING
>>  1152 00001000000010000000000000000000 08080000    134742016 DMC WARNING
>>  1152 00001000001000000000000000000000 08200000    136314880 DMC WARNING
>>  1153 00010000000000000000000000000000 10000000    268435456
>>  1160 00000000000000000000000000000001 00000001            1
>>  1161 00000000000000000000000000000010 00000002            2
>>  1161 00000000000000000000000000000011 00000003            3
>>  1162 00000000000000000000000000000100 00000004            4
>>  1162 00000000000000000000000000000101 00000005            5
>>  1162 00000000000000000000000000000110 00000006            6
>>  1162 00000000000000000000000000001100 0000000c           12
>>  1163 00000000000000000000000000001000 00000008            8
>>  1163 00000000000000000000000000001100 0000000c           12
>>  1164 00000000000000000000000000010000 00000010           16
>>  1165 00000000000000000000000000000000 00000000            0 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000100000 00000020           32 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000100001 00000021           33 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000100011 00000023           35 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000101000 00000028           40 Key in Key
>> Switch Door Ajar
>>  1165 00000000000000000000000000101001 00000029           41 Key in Key
>> Switch Door Ajar
>>  1166 00000000000000000000000000000000 00000000            0 Release Parking
>> Brake
>>  1166 00000000000000000000000001000000 00000040           64 Release Parking
>> Brake
>>  1166 00000000000000000000000001000100 00000044           68 Release Parking
>> Brake
>>  1167 00000000000000000000000010000000 00000080          128
>>  1169 00000000000000000000001000000000 00000200          512 Charge port open
>>  1169 00000000000000000000001000100000 00000220          544 Charge port open
>>  1170 00000000000000000000010000000000 00000400         1024 Tow Mode is not
>>  1171 00000000000000000000100000000000 00000800         2048
>>  1173 00000000000000000010000000000000 00002000         8192
>>  1173 00000000000000000010000000000001 00002001         8193
>>  1173 00000000000000000010000000100000 00002020         8224
>>  1174 00000000000000000100000000000000 00004000        16384
>>  1174 00000000000000000100000000000010 00004002        16386
>>  1174 00000000000000000100000000000100 00004004        16388
>>  1174 00000000000000000100000000000110 00004006        16390
>>  1174 00000000000000000100000000001100 0000400c        16396
>>  1174 00000000000000000100000000010000 00004010        16400
>>  1174 00000000000000000100000000010100 00004014        16404
>>  1174 00000000000000000100000000100000 00004020        16416
>>  1174 00000000000000000100000001000000 00004040        16448
>>  1400 00000000000000000000000000000001 00000001            1
>>  1401 00000000000000000000000000000010 00000002            2
>>  1412 00000000000000000001000000000000 00001000         4096
>>  1415 00000000000000001000000000000000 00008000        32768
>>  1426 00000100000000000000000000000000 04000000     67108864
>>  1442 01000000000000000000000000000100 40000004   1073741828
>>  1442 01000000000000000000000000001100 4000000c   1073741836
>>  1443 00000000000000000000000000001000 00000008            8
>>  1443 00000000000000000000000000001100 0000000c           12
>>  1443 01000000000000000000000000001100 4000000c   1073741836
>>  1450 00000000000000000000010000000000 00000400         1024
>>  1451 00000000000000000000110000000000 00000c00         3072
>>  1461 00000000001000000000000000000000 00200000      2097152
>>  1463 00000000100000000000000000000000 00800000      8388608
>>  1469 00100000000000000000000000000000 20000000    536870912
>>  1470 01000000000000000000000000000100 40000004   1073741828
>>  1470 01000000000000000000000000001100 4000000c   1073741836
>>  1471 10100000000000000000000000000000 a0000000   2684354560
>>  1493 00000000000000000000000000001000 00000008            8
>>  1545 00000000000000000000000010000000 00000080          128
>>  1545 01000000000000000000000000000100 40000004   1073741828
>>  1554 00000000010000000000000000000000 00400000      4194304
>>  1554 10000001001000100011100010110100 812238b4   2166503604
>>  1560 00000000000000000000000000000000 00000000            0
>>  1560 00000000000000000000000000100000 00000020           32
>>  1560 00000000000000000000000010000000 00000080          128
>>  1560 00000000000000000000001000000000 00000200          512
>>  1562 00000000000000000000000000100000 00000020           32
>>  1562 00000000000000000000000001000000 00000040           64
>>  1562 00000000000000000010000000000000 00002000         8192
>>  1562 10000001001010111011100010110100 812bb8b4   2167126196
>>  1660 00000000000000000000000000010000 00000010           16
>>  1661 00000000000000000000000000100000 00000020           32
>>  1664 00000000000000000000000100000000 00000100          256
>>  3003 00000000000000000000000000000100 00000004            4
>>  3008 00000000000000000000000010000000 00000080          128
>>  3009 00000000000000000000000100000000 00000100          256
>>  3010 00000000000000000000001000000000 00000200          512
>>  3011 00000000000000000000010000000000 00000400         1024
>>  3012 00000000000000000000100000000000 00000800         2048
>>  3012 00000000000000000000110000000000 00000c00         3072
>>  3018 00000000000000100000100000000000 00020800       133120
>>  3020 00000000000010000000000000000000 00080000       524288
>>  3021 00000000000100000000000000000000 00100000      1048576
>>  3023 00000000010000000000000000000000 00400000      4194304
> Again, I don't see it.
> Any ideas? I'm stumped.
> OvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131104/a7309db2/attachment.htm>
Type: image/jpg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131104/a7309db2/attachment-0001.jpg>
Name: 131004 Roadster Pump Failure[1].png
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131104/a7309db2/attachment-0001.png>
