[Ovmsdev] Debug vs Normal messages in Tesla Roadster
Pierre Uhl pi.uhl at bluewin.ch
Mon Nov 4 16:17:09 HKT 2013
Here is another error fort he list:
This happen, when the circumference of the front wheels are bigger (or
smaller) than the rear wheels (Pirelli Winter Tyres).
But this error only show up in Debug-Only Msg. Mode. Not in Debug Text.
Pierre
Von: ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Webb-Johnson
Gesendet: Montag, 4. November 2013 01:14
An: OVMS Developers
Betreff: [Ovmsdev] Debug vs Normal messages in Tesla Roadster
I'm not having much luck trying to differentiate between debug and normal
alert messages in the Tesla Roadster. So, here is my working so far, and
calling out for ideas.
First, here is what is known about the CAN bus message relating to this:
        Error Notification
                ID=0x100
                B1=0x93
                B2=On, Off, Severity, etc, indication
                B3=Error code LSB
                B4=Error code MSB (error code 0xFFFF means no error)
                B5=Data LSB
                B6=Data
                B7=Data
                B8=Data MSB
                N.B. Regarding B2, we've seen:
                        0x01 = 00000001b = Show Alert
                        0x00 = 00000000b = Cancel Alert
                        0x05 = 00000101b = Show Alert
                        0x04 = 00000100b = Cancel Alert
                        0x15 = 00010101b = Show Message
                        0x14 = 00010100b = End Message
                     Suggestion is that bit0 is set when alert is raised,
and zeroed when alert is cleared.
Here is some raw can bus messages showing some alerts coming and going:
         6.6947 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
        13.4250 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        20.1151 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        26.8368 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        33.5484 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        40.2862 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        46.9766 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        53.6772 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        60.3577 100 93 05 78 03 00 01 00 00    ->VDS (message to VDS 93)
        63.2089 100 93 04 78 03 00 00 00 00    ->VDS (message to VDS 93)
        67.0663 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
        73.7502 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
        80.2421 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
        80.4511 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
        87.1387 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
        93.8198 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
       100.5295 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
       107.2297 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
       113.9373 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
       120.6307 100 93 05 8D 04 20 00 00 00    ->VDS (message to VDS 93)
       121.7428 100 93 04 8D 04 20 00 00 00    ->VDS (message to VDS 93)
       127.3396 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       128.3633 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
       134.0215 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
       140.7018 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
       147.4018 100 93 05 91 04 00 02 00 00    ->VDS (message to VDS 93)
       147.9951 100 93 04 91 04 00 02 00 00    ->VDS (message to VDS 93)
       154.1413 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       160.8654 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       167.5743 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       174.5784 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       181.3024 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       188.0697 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       194.7832 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
       201.4736 100 93 00 FF FF 00 00 00 00    ->VDS (message to VDS 93)
The message shown on the car's VDS includes 4 bytes of data, so we are
assuming that is B5..B8.
The most likely seemed to be B2, which we don't normally report back to the
server. So, I switched my car to report that rather that the Data (B5..B8)
and here is what I got:
rx msg P ETR2N,1165,5
rx msg P ETR2N,888,5
rx msg P ETR2N,1124,5
rx msg P ETR2N,1166,5
rx msg P ETR2N,1146,5
rx msg P ETR2N,954,1
1146 (DMC Motor Fan Problem) is a debug message. 954 (line voltage lost
sync), 1166 (release parking brake), 888 (disarm vehicle with keyfob), 1165
(door ajar) and 1124 (unsafe gear shift) are not. The last number (5 or 1)
is the B2 value corresponding to the alert. I have no idea why 954 should be
B2=1 and the others B2=5, but it seems to have no relation to the debug
level of the alert.
So, how about the ID number of the alert itself? Well, here is the list of
known alerts, with the ID number shown in binary, hexadecimal and decimal,
followed by the message:
0000000000011001 0019    25 Memory Stick transfer in progress (%d%%)
0000000000110101 0035    53 GPS: No data fault
0000000100001101 010d   269 BSM: Negative contactor/economizer stuck low
0000000100011011 011b   283 BSM: Isolation fault
0000000100011110 011e   286 BSM: Isolation fault while contactors closed
0000000100011111 011f   287 Power train Problem Service Required
0000000110011001 0199   409 TPMS: Hardware Error
0000000110101100 01ac   428 12V Battery Service Required
0000001001011100 025c   604 Battery Low Power Reduced
0000001001011110 025e   606 ESS: Range Mode Remaining charge uncertain
0000001001100011 0263   611 ESS: Almost empty - Car stops in 1 mile
0000001101110010 0372   882 Before starting, charge port door must be closed
0000001101111000 0378   888 Disarm vehicle with key fob before starting
0000001110100110 03a6   934 DMC FW: Line OverCurrent Peak Fault
0000001110101000 03a8   936 Charging Problem
0000001110101001 03a9   937 Charge Problem Extension Cord Detected
0000001110110001 03b1   945 System too hot - Vehicle shutting down
0000001110111001 03b9   953 Line Voltage Lost Sync
0000001110111010 03ba   954 Line Voltage Lost Sync
0000001111001110 03ce   974 DMC FW: Pole Current Error Fault
0000001111010101 03d5   981 DMC FW: Bad State Transition Fault
0000001111000000 03c0   960 DMC FW: VBrickMax versus VBattery Error fault
0000010000110001 0431  1073 DMC FW: PhaseA OverTemp warning. Torque limited
0000010000110010 0432  1074 DMC FW: PhaseA Temp Diff warning
0000010000110110 0436  1078 DMC FW: PhaseC Temp Diff warning
0000010000111100 043c  1084 External Charger Problem
0000010001000100 0444  1092 Do not plug in charge cable while driving
0000010001001111 044f  1103 ABS & Traction Control Problems. Service
Required.
0000010001100100 0464  1124 Unsafe Gear Shift Transition Denied
0000010001111000 0478  1144 Powertrain Problem Service Required
0000010001111010 047a  1146 DMC Motor Fan Problem
0000010010000000 0480  1152 DMC WARNING Charge Thermal Limit
0000010010001101 048d  1165 Key in Key Switch Door Ajar
0000010010001110 048e  1166 Release Parking Brake
0000010010010001 0491  1169 Charge port open
0000010010010010 0492  1170 Tow Mode is not available while car is on
0000010010010110 0496  1174 Fasten Seatbelt
0000010110001000 0588  1416 Low Power System Service Required
0000010110110111 05b7  1463 HVAC: Compressor OverTemp
0000010110111001 05b9  1465 HVAC: Low current pump fault
0000010110111101 05bd  1469 HVAC: Compressor comms timeout
0000010110111111 05bf  1471 HVAC: Compressor DTC comms timeout
0000100000011110 081e  2078 There was a problem processing your request
The "DMC" prefix is supposed to indicate a debug message. I don't see any
pattern. It has also been reported that one single ID can have both debug
and non-debug variants to the message - see:
http://www.teslamotorsclub.com/showwiki.php?title=Roadster
So, here is all the error codes and data that we've seen for the past few
months (error code, followed by data bytes in binary, hex and decimal):
    0 00000000000000000000000000000000 00000000            0
    3 00000000000000000000000000000000 00000000            0
    3 00000000000000000000000000000100 00000004            4
    3 00000000000000000000000000100000 00000020           32
    3 00000000001000000000000000000000 00200000      2097152
    3 10000001001000100011100010110100 812238b4   2166503604
    3 10000001001010111011100010110100 812bb8b4   2167126196
    3 10000001001011001011100010110100 812cb8b4   2167191732
   10 00000000000000000000000000010000 00000010           16
   10 00000000000000000000000000100000 00000020           32
   10 00000000000000000000100000000000 00000800         2048
   10 01000000000000000000000000000100 40000004   1073741828
   19 00000000000000000000000000000000 00000000            0
   25 00000000000000000000000000000000 00000000            0 Memory Stick
   25 00000000000000000000000000000001 00000001            1 Memory Stick
   25 00000000000000000000000000000010 00000002            2 Memory Stick
   25 00000000000000000000000000000011 00000003            3 Memory Stick
   25 00000000000000000000000000101111 0000002f           47 Memory Stick
   25 00000000000000000000000000110000 00000030           48 Memory Stick
   25 00000000000000000000000001000000 00000040           64 Memory Stick
   25 00000000000000000000000001000001 00000041           65 Memory Stick
   25 00000000000000000000000001000010 00000042           66 Memory Stick
   25 00000000000000000000000001100001 00000061           97 Memory Stick
   25 00000000000000000000000001100011 00000063           99 Memory Stick
   25 00000000000000000000000001100100 00000064          100 Memory Stick
   29 00000000000000000000000000000000 00000000            0
   32 00000000000000000000000000000010 00000002            2
   50 00000000000000000000000000000000 00000000            0
   52 00000000000000000000000000000100 00000004            4
   53 00000000000000000000000000000000 00000000            0
   53 00000000000000000000000000001000 00000008            8
   55 00000000000000000000000000100000 00000020           32
   57 00000000000000000000000000000000 00000000            0
   57 00000000000000000000000010000000 00000080          128
   63 00000000000000000010000000000000 00002000         8192
  104 00000000000000000100000000000000 00004000        16384
  257 00000000000000000000000000000001 00000001            1
  263 00000000000000000000000001000000 00000040           64
  264 00000000000000000000000010000000 00000080          128
  269 00000000000000000001010000000000 00001400         5120 BSM: Negative
  270 00000000000000000010100000000000 00002800        10240
  271 00000000000000000100000000000000 00004000        16384
  276 00000000000010000000000000000000 00080000       524288
  283 00100100000000000000000000000000 24000000    603979776
  283 01000100000000000000000000000000 44000000   1140850688
  286 00100100000000000000000000000000 24000000    603979776
  287 01000100000000000000000000000000 44000000   1140850688 Power train
  399 00010000000000000000000000000000 10000000    268435456
  399 10000001001000100011100010110100 812238b4   2166503604
  399 10000001001000111011100010110100 8123b8b4   2166601908
  399 10000001001010111011100010110100 812bb8b4   2167126196
  399 10000010111110011011100010110100 82f9b8b4   2197403828
  400 00000000000000000000000000000100 00000004            4
  400 00000000000000000000000100000000 00000100          256
  400 00010000000000000000000000000000 10000000    268435456
  400 10000001001000100011100010110100 812238b4   2166503604
  400 10000001001000110011100010110100 812338b4   2166569140
  400 10000001001000111011100010110100 8123b8b4   2166601908
  400 10000001001010111011100010110100 812bb8b4   2167126196
  400 10000010111110011011100010110100 82f9b8b4   2197403828
  401 00000000000000000000000000000001 00000001            1
  403 00000000000000000000000000000100 00000004            4
  405 00000000000000000000000000010000 00000010           16
  407 00000000000000000000000001000000 00000040           64
  409 00000000000000000000000100000000 00000100          256 TPMS: Hardware
Error
  415 00000000000000000100000000000000 00004000        16384
  416 00000000000000001100000000000000 0000c000        49152
  420 00000000000000000000000000000001 00000001            1
  428 00000000000000000000000000000000 00000000            0 12V Battery
Service Required
  428 00000000000000000000000000000001 00000001            1 12V Battery
Service Required
  428 00000000000000000000000000000100 00000004            4 12V Battery
Service Required
  428 00000000000000000000000000010000 00000010           16 12V Battery
Service Required
  428 00000000000000000000000000100000 00000020           32 12V Battery
Service Required
  428 00000000000000000000000001000000 00000040           64 12V Battery
Service Required
  428 00000000000000000000000010000000 00000080          128 12V Battery
Service Required
  428 00000000000000000000000100000000 00000100          256 12V Battery
Service Required
  428 10000001001000011011100010110100 8121b8b4   2166470836 12V Battery
Service Required
  428 10000001001000011011110110011100 8121bd9c   2166472092 12V Battery
Service Required
  428 10000001001000100011100010110000 812238b0   2166503600 12V Battery
Service Required
  428 10000001001000100011100010110100 812238b4   2166503604 12V Battery
Service Required
  428 10000001001000100011110110011100 81223d9c   2166504860 12V Battery
Service Required
  428 10000001001001000011100010110100 812438b4   2166634676 12V Battery
Service Required
  428 10000001001001000011110110011100 81243d9c   2166635932 12V Battery
Service Required
  428 10000001001010111011100010110100 812bb8b4   2167126196 12V Battery
Service Required
  428 10000001001010111011110110011100 812bbd9c   2167127452 12V Battery
Service Required
  529 00000000000000000000000000000000 00000000            0
  529 00000000000000000000000000000100 00000004            4
  529 00000000000000000000000000001000 00000008            8
  529 00000000000000000000000000001100 0000000c           12
  529 00000000000000000000000000100000 00000020           32
  529 00000000000000000000000100000000 00000100          256
  529 00000000000000000000000100000100 00000104          260
  529 00000100000000000000000000000000 04000000     67108864
  529 00010000000000000000000000000000 10000000    268435456
  529 00100100000000000000000000000000 24000000    603979776
  529 01000000000000000000000000000100 40000004   1073741828
  529 01000000000000000000000000001100 4000000c   1073741836
  529 10000001001000100011100010110100 812238b4   2166503604
  529 10000001001001001011100010110100 8124b8b4   2166667444
  530 10000001001010111011100010110100 812bb8b4   2167126196
  537 00000000000000000010000000000000 00002000         8192
  537 00010000000000000000000000000000 10000000    268435456
  537 10000001001000100011100010110100 812238b4   2166503604
  537 10000001001000111011100010110100 8123b8b4   2166601908
  538 10000001001000100011100010110100 812238b4   2166503604
  538 10000001001000100011110110011100 81223d9c   2166504860
  539 00010000000000000000000000000000 10000000    268435456
  539 10000001001011000011100010110100 812c38b4   2167158964
  539 10000001001011000011110110011100 812c3d9c   2167160220
  601 00000000000000000000000000000010 00000002            2
  604 00000000000000000000000000010000 00000010           16 Battery Low
Power Reduced
  604 00000000000000000000000000010010 00000012           18 Battery Low
Power Reduced
  606 00000000000000000000000001000000 00000040           64
  608 00000000000000000000000100000000 00000100          256
  609 00000000000000000000001000000000 00000200          512
  610 00000000000000000000010000000000 00000400         1024
  611 00000000000000000000100000000000 00000800         2048
  881 00000000000000000000000000000010 00000002            2
  882 00000000000000000000000000000100 00000004            4 Before
  883 00000000000000000000000000001000 00000008            8
  887 00000000000000000000000010000000 00000080          128
  888 00000000000000000000000100000000 00000100          256 Disarm vehicle
  888 00000000000000000000000100000100 00000104          260 Disarm vehicle
  920 00000000000010000000000000000000 00080000       524288
  925 00000000000000000000000100000000 00000100          256
  925 00000001000000000000000000000000 01000000     16777216
  934 00000000000000000000000000000010 00000002            2
  935 00000000000000000000000000000100 00000004            4
  936 00000000000000000000000000001000 00000008            8 Charging
Problem
  936 00000000000000000000000000001010 0000000a           10 Charging
Problem
  937 00000000000000000000000000010000 00000010           16 Charge Problem
  945 00000000000000000001000000000000 00001000         4096
  953 00000000000000000000000000000000 00000000            0 Line Voltage
Lost Sync
  953 00000000000100000000000000000000 00100000      1048576 Line Voltage
Lost Sync
  954 00000000001000000000000000000000 00200000      2097152 Line Voltage
Lost Sync
  955 00000000010000000000000000000000 00400000      4194304
  974 00000000000000000000001000000000 00000200          512 DMC FW: Pole
Current Error Fault
  977 00000000000000000001000000000000 00001000         4096
  981 00000000000000010000000000000000 00010000        65536 DMC FW: Bad
 1022 00000010000000000000000000000000 02000000     33554432
 1023 00000100000000000000000000000000 04000000     67108864
 1023 00000110000000000000000000000000 06000000    100663296
 1063 00000000000000000000000000000100 00000004            4
 1065 00000000000000000000000000010000 00000010           16
 1067 00000000000000000000000001000000 00000040           64
 1069 00000000000000000000000100000000 00000100          256
 1070 00000000000000000000001000000000 00000200          512
 1070 00000000000000000000001100000000 00000300          768
 1073 00000000000000000001000000000000 00001000         4096 DMC FW: PhaseA
 1074 00000000000000000010000000000000 00002000         8192 DMC FW: PhaseA
Temp Diff warning
 1076 00000000000000001000000000000000 00008000        32768
 1077 00000000000000010000000000000000 00010000        65536
 1077 00000000000000011000000000000000 00018000        98304
 1081 00000000000100000000000000000000 00100000      1048576
 1082 00000000001000000000000000000000 00200000      2097152
 1084 00000000100000000000000000000000 00800000      8388608 External
Charger Problem
 1084 00000000100000000000000000010000 00800010      8388624 External
Charger Problem
 1085 00000001000000000000000001000000 01000040     16777280
 1086 00000010000000000000000000000000 02000000     33554432
 1087 00000100000000000000000000000000 04000000     67108864
 1092 10000000000000000000000000000000 80000000   2147483648 Do not plug in
 1094 00000000000000000000000000000010 00000002            2
 1095 00000000000000000000000000000100 00000004            4
 1096 00000000000000000000000000000000 00000000            0
 1096 00000000000000000000000000001000 00000008            8
 1103 00000000000000000000010000000000 00000400         1024 ABS & Traction
Control Problems. Service Required.
 1124 10000000000000000000000000000000 80000000   2147483648 Unsafe Gear
 1131 00000000000000000000000001000000 00000040           64
 1133 00000000000000000000000100000000 00000100          256
 1144 00000000000010000000000000000000 00080000       524288 Powertrain
 1146 00000000001000000000000000000000 00200000      2097152 DMC Motor Fan
Problem
 1146 00001000001000000000000000000000 08200000    136314880 DMC Motor Fan
Problem
 1152 00001000000000000000000000000000 08000000    134217728 DMC WARNING
 1152 00001000000010000000000000000000 08080000    134742016 DMC WARNING
 1152 00001000001000000000000000000000 08200000    136314880 DMC WARNING
 1153 00010000000000000000000000000000 10000000    268435456
 1160 00000000000000000000000000000001 00000001            1
 1161 00000000000000000000000000000010 00000002            2
 1161 00000000000000000000000000000011 00000003            3
 1162 00000000000000000000000000000100 00000004            4
 1162 00000000000000000000000000000101 00000005            5
 1162 00000000000000000000000000000110 00000006            6
 1162 00000000000000000000000000001100 0000000c           12
 1163 00000000000000000000000000001000 00000008            8
 1163 00000000000000000000000000001100 0000000c           12
 1164 00000000000000000000000000010000 00000010           16
 1165 00000000000000000000000000000000 00000000            0 Key in Key
Switch Door Ajar
 1165 00000000000000000000000000100000 00000020           32 Key in Key
Switch Door Ajar
 1165 00000000000000000000000000100001 00000021           33 Key in Key
Switch Door Ajar
 1165 00000000000000000000000000100011 00000023           35 Key in Key
Switch Door Ajar
 1165 00000000000000000000000000101000 00000028           40 Key in Key
Switch Door Ajar
 1165 00000000000000000000000000101001 00000029           41 Key in Key
Switch Door Ajar
 1166 00000000000000000000000000000000 00000000            0 Release Parking
Brake
 1166 00000000000000000000000001000000 00000040           64 Release Parking
Brake
 1166 00000000000000000000000001000100 00000044           68 Release Parking
Brake
 1167 00000000000000000000000010000000 00000080          128
 1169 00000000000000000000001000000000 00000200          512 Charge port
open
 1169 00000000000000000000001000100000 00000220          544 Charge port
open
 1170 00000000000000000000010000000000 00000400         1024 Tow Mode is not
 1171 00000000000000000000100000000000 00000800         2048
 1173 00000000000000000010000000000000 00002000         8192
 1173 00000000000000000010000000000001 00002001         8193
 1173 00000000000000000010000000100000 00002020         8224
 1174 00000000000000000100000000000000 00004000        16384
 1174 00000000000000000100000000000010 00004002        16386
 1174 00000000000000000100000000000100 00004004        16388
 1174 00000000000000000100000000000110 00004006        16390
 1174 00000000000000000100000000001100 0000400c        16396
 1174 00000000000000000100000000010000 00004010        16400
 1174 00000000000000000100000000010100 00004014        16404
 1174 00000000000000000100000000100000 00004020        16416
 1174 00000000000000000100000001000000 00004040        16448
 1400 00000000000000000000000000000001 00000001            1
 1401 00000000000000000000000000000010 00000002            2
 1412 00000000000000000001000000000000 00001000         4096
 1415 00000000000000001000000000000000 00008000        32768
 1426 00000100000000000000000000000000 04000000     67108864
 1442 01000000000000000000000000000100 40000004   1073741828
 1442 01000000000000000000000000001100 4000000c   1073741836
 1443 00000000000000000000000000001000 00000008            8
 1443 00000000000000000000000000001100 0000000c           12
 1443 01000000000000000000000000001100 4000000c   1073741836
 1450 00000000000000000000010000000000 00000400         1024
 1451 00000000000000000000110000000000 00000c00         3072
 1461 00000000001000000000000000000000 00200000      2097152
 1463 00000000100000000000000000000000 00800000      8388608
 1469 00100000000000000000000000000000 20000000    536870912
 1470 01000000000000000000000000000100 40000004   1073741828
 1470 01000000000000000000000000001100 4000000c   1073741836
 1471 10100000000000000000000000000000 a0000000   2684354560
 1493 00000000000000000000000000001000 00000008            8
 1545 00000000000000000000000010000000 00000080          128
 1545 01000000000000000000000000000100 40000004   1073741828
 1554 00000000010000000000000000000000 00400000      4194304
 1554 10000001001000100011100010110100 812238b4   2166503604
 1560 00000000000000000000000000000000 00000000            0
 1560 00000000000000000000000000100000 00000020           32
 1560 00000000000000000000000010000000 00000080          128
 1560 00000000000000000000001000000000 00000200          512
 1562 00000000000000000000000000100000 00000020           32
 1562 00000000000000000000000001000000 00000040           64
 1562 00000000000000000010000000000000 00002000         8192
 1562 10000001001010111011100010110100 812bb8b4   2167126196
 1660 00000000000000000000000000010000 00000010           16
 1661 00000000000000000000000000100000 00000020           32
 1664 00000000000000000000000100000000 00000100          256
 3003 00000000000000000000000000000100 00000004            4
 3008 00000000000000000000000010000000 00000080          128
 3009 00000000000000000000000100000000 00000100          256
 3010 00000000000000000000001000000000 00000200          512
 3011 00000000000000000000010000000000 00000400         1024
 3012 00000000000000000000100000000000 00000800         2048
 3012 00000000000000000000110000000000 00000c00         3072
 3018 00000000000000100000100000000000 00020800       133120
 3020 00000000000010000000000000000000 00080000       524288
 3021 00000000000100000000000000000000 00100000      1048576
 3023 00000000010000000000000000000000 00400000      4194304
Again, I don't see it.
Any ideas? I'm stumped.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131104/03782c89/attachment.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131104/03782c89/attachment.jpg>
