[Ovmsdev] OVMS Leaf Support
    Robert Sharpe
    robert.sharpe at evergreen-consulting.co.uk
    Sun Nov  3 16:52:07 HKT 2013
Hi Kevin,
I am keen to start helping out on the Leaf development.
It's been 3 weeks and I just wandered what the progress with the OVMS hardware is ?
Rob
---- On Mon, 14 Oct 2013 15:01:15 +0100 <robert.sharpe at evergreen-consulting.co.uk> wrote ----
Hi Kevin,
Thanks a lot for your kind offer.
I should set expectations that I am an out of practice and slow coder, but I will do what I can to help.  I can probably help more with test, debug and coordination.
So if you are still happy then, as I dont have any OVMS kit, I will need an OVMS and correct cable.
Can someone point me to a developer beginner's instructions for what else is required to develop/test, e.g. programmer, sniffer, code repository login, CM procedures, etc
It helps me, and hopefully anyone else working on the project, if we can agree the breakdown of work.  As you may have already seen I have suggested a post for the Leaf development at http://www.openvehicles.com/node/111
Nikki/Mark shall we use that as a way of planning and tracking the work ?
Rob
On Oct 14, 2013, at 2.21PM, Nikki Gordon-Bloomfield wrote:
Hi Kevin,
That's very generous. Happy to test OVMS in my LEAF, so I guess another OVMS kit with a righty cable?
Nikki.
On 14 Oct 2013, at 13:47, Kevin Sharpe ZCW <kevin.sharpe at zerocarbonworld.org">target="_blank">kevin.sharpe at zerocarbonworld.org> wrote:
    Rob, Mark (C), Nikki,
 If it helps, I'm happy to provide each of you with OVMS hardware FOC in return for your efforts on the Leaf development :-)
 Let me know what you need,
             Kevin Sharpe | Founder & Patron
 Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
 kevin.sharpe at zerocarbonworld.org | http://www.zerocarbonworld.org/ | twitter.com/zerocarbonworld
 Zero Carbon World is a UK Registered Charity #1141347
   From: Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk">target="_blank">robert.sharpe at evergreen-consulting.co.uk>
 Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk">target="_blank">ovmsdev at lists.teslaclub.hk>
 Date: Monday, 14 October 2013 13:41
 Subject: Re: [Ovmsdev] OVMS Leaf Support
   Hi Mark,
  This looks very interesting.
  I am out today but will look in more depth tomorrow.
  Rob
 ---- On Mon, 14 Oct 2013 10:08:41 +0100 Mark Webb-Johnson <mark at webb-johnson.net">target="_blank">mark at webb-johnson.net> wrote ----
   I think the leaf spy app shows what can be done. It only uses standard OBDII, with just one can bus. It could also be using the other non-can OBDII buses, but I doubt it.
 Shame it is not open source, but the leaf codes are pretty well documented now.
 On 14 Oct, 2013, at 4:00 pm, Nikki Gordon-Bloomfield <nikki at aminorjourney.com">target="_blank">nikki at aminorjourney.com> wrote:
  Oh yes, there are multiple CAN busses on the LEAF. The standard one, which is where all the data below comes from, an the EV can -- that would require some clever doodads, since both are on the same physical connector -- just different pins.
 Nikki.
  On 14 Oct 2013, at 04:50, Mark Webb-Johnson <mark at webb-johnson.net">target="_blank">mark at webb-johnson.net> wrote:
   Robert,
 Sorry for the delay in response - I’ve been off grid parenting for the past 24 hours.
 I think @Nufkin has done some preparation work, and we have a stub vehicle support file (vehicle_nissanleaf.c), but nothing working yet.
 This App shows what can be done:
   https://play.google.com/store/apps/details?id=com.Turbo3.Leaf_Spy_Pro
 using just the OBD-II port (I assume all the single master CAN bus, but perhaps also other buses on OBD-II).
 I’m very excited by this, and more than willing to help, but I don’t have the car here so am limited in what I can do.
 Can you work with @nufkin (and his other half) on this?
 You would need some sort of CAN bus decoder (perhaps just an OBD-II dongle, or CAN-USB adaptor), plus an OVMS module and PICKIT for firmware download. If you use MAC OSX, the development environment is simple to setup - for windows there are a few more hoops to jump through. Lastly, a RS232-USB adaptor is useful (but not essential).
   On 13 Oct, 2013, at 4:00 pm, Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk">target="_blank">robert.sharpe at evergreen-consulting.co.uk> wrote:
 Hi,
 < ovmsdev-request at lists.teslaclub.hk">target="_blank">ovmsdev-request at lists.teslaclub.hk>
 Is anyone working on Leaf support?
 I am interested in helping if I can and have started a discussion at http://openvehicles.com/comment/220#comment-220 to capture were we are with the Leaf.
 Robert Sharpe (Technical Director)
 07711 252971
http://www.facebook.com/EvergreenConsultingLtd
 http://twitter.com/EGCtechnical
 http://uk.linkedin.com/in/arsharpe
 www.evergreen-consulting.co.uk
Your Plugged-in Partner
Support the future and switch to a renewable energy supplier such as Good Energy
Evergreen Consulting is the trading name of Sharpe Consultants Ltd
 < /ovmsdev-request at lists.teslaclub.hk">target="_blank">/ovmsdev-request at lists.teslaclub.hk>_______________________________________________
 OvmsDev mailing list
 OvmsDev at lists.teslaclub.hk">target="_blank">OvmsDev at lists.teslaclub.hk
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20131103/6a154712/attachment.html>
