[Ovmsdev]  Re: Ampera remote start/stop function
Mon Mar 4 08:39:21 HKT 2013
Richard,
It is possible that both OnStar and the KeyFob use the same codes, bus and mechanism. But also possible that they use different mechanisms. In both cases the commands should be going from OnStar/KeyFob to the car systems.
As OnStar is a separate module, rather than something tightly integrated with the alarm system, I am more hopeful that it will offer an 'instruction command style' (lock doors, unlock doors, start engine, stop engine, etc) interface to the car.
So the reason to look at both is to (a) see if there are similarities in the data, (b) more chance that one is on the main can bus we are on, and (c) improve our chances of success.
Thanks for your help with this. Hopefully we'll find something in the data you uploaded today.
On 4 Mar, 2013, at 2:03 AM, Richard G Jones wrote:
> Regarding the failure of key fob remote start as discussed in the logs I sent earlier, I realize now that it only works if you press lock shortly before remote start.
> I had locked the doors before the test but in my haste forgot to retry locking. Was rushing before an appointment have not tried the keyfob remote start on the volt before. Confirmed it works now.
> I can get a correct keyfob remote start log later.
> Btw if keyfob remote start works why not use this in ovms?. Why the need for onstar logs?
> Presumably European amperas have keyfob remote start.
> Getting onstar logs is interesting of course just wondering what I'm missing re remote start.
> Sent from my phablet, scuse the typos
> David Peilow <david at peilow.com> wrote:
> Hi,
> Have a look at the last post in this thread...
> http://gm-volt.com/forum/showthread.php?29073-How-to-enable-quot-OnStar-quot-like-services-for-Volt-in-Europe
> SWCAN?
> David
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130304/94cd0e8a/attachment.htm>
