[Ovmsdev] Strange Twizy Message.
Nikki Gordon-Bloomfield nikki at littlecollie.com
Thu Jun 6 20:25:52 HKT 2013
Hey Michael,
I log everything and download every night to my Raspberry Pi, so I can send you the logs tomorrow.
Nikki.
On 6 Jun 2013, at 13:21, Michael Balzer <dexter at expeedo.de> wrote:
> Hi Nikki,
> not sure yet, I also had this effect once short before charge end.
> I assumed it was some kind of RAM corruption as I had other RAM effects around then too.
> Btw, the alert values are deviations, i.e. "SD" = standard deviation and "+4075mV" would mean cell 1 is 4.075 V above average -- that's of course nonsense.
> You can query the values using the "BATT V" and "BATT T" SMS commands, and you can reset by "BATT R". Could be useful if you fetch the BattPack and BattCell history msgs before and send them to me.
> Thanks,
> Am 06.06.2013 11:34, schrieb Nikki Gordon-Bloomfield:
>> Hi guys
>> Just got the following message from my car:
>> "Volts: !SD:4075mV !C1:+4075mV Temps: !SD:225C !M1:-1C"
>> It's about 10 degrees C right now, and SOC is reported as 82 percent. Any ideas what's going on?   I can tell the voltage is okay… but the temperature warning???
>> Nikki.
