[Ovmsdev] Strange Twizy Message.
Thu Jun 6 20:21:06 HKT 2013
Hi Nikki,
not sure yet, I also had this effect once short before charge end.
I assumed it was some kind of RAM corruption as I had other RAM effects
around then too.
Btw, the alert values are deviations, i.e. "SD" = standard deviation and
"+4075mV" would mean cell 1 is 4.075 V above average -- that's of course
nonsense.
You can query the values using the "BATT V" and "BATT T" SMS commands,
and you can reset by "BATT R". Could be useful if you fetch the BattPack
and BattCell history msgs before and send them to me.
Thanks,
Am 06.06.2013 11:34, schrieb Nikki Gordon-Bloomfield:
> Hi guys
> Just got the following message from my car:
> "Volts: !SD:4075mV !C1:+4075mV Temps: !SD:225C !M1:-1C"
> It's about 10 degrees C right now, and SOC is reported as 82 percent. Any ideas what's going on? I can tell the voltage is okay… but the temperature warning???
> Nikki.
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130606/9b6e4058/attachment.vcf>
