[Ovmsdev] Android App
Wed Jan 30 00:10:24 HKT 2013
Mark,
my parktime is always 0, as I currently have no parking detection, but
the App shows it as parking. It shows "just now" most of the time (also
right now), but I also saw some "x minutes" displays there. doors1 bit7
is set correctly by the Twizy.
I found the joystick now, that could have passed as a "hidden" feature ;-)
The USSD code entry only allows digits, at least "*" and "#" also need
to be allowed.
Am 29.01.2013 02:37, schrieb Mark Webb-Johnson:
>> - constantly shows "parking", although the Twizy does not feed the
>> parking timer
> I just tested on my Roadster, with both Android and iOS Apps, and this
> seems to work as it should (for me).
> The logic in the Apps is that the car is parked if "!carstarted and
> parktime>0".
> Carstarted is:
>     unsigned char car_doors1 [bit 7]
>     A bit used to signal whether the car is turned on or off. Set to 1
>     if the car ignition switch is ON, otherwise 0.
> There is a little bit of code in the vehicle_voltampera to handle the
> parking timer. As we don't know the 'car on' signal for the
> Volt/Ampera, yet, we just use the gear selector PARK.
>       else if ((CANctrl & 0x07) == 5)        // Acceptance Filter 5
>     (RXF5) = CAN ID 135
>         if (can_databuffer[0] == 0)
>           { // Car is in PARK
>           car_doors1 |= 0x40;     // NOT PARK
>           car_doors1 &= ~0x80;    // CAR OFF
>           if (car_parktime == 0)
>             car_parktime = car_time-1;    // Record it as 1 second
>     ago, so non zero report
>             net_req_notification(NET_NOTIFY_ENV);
>         else
>           { // Car is not in PARK
>           car_doors1 &= ~0x40;    // PARK
>           car_doors1 |= 0x80;     // CAR ON
>           if (car_parktime != 0)
>             car_parktime = 0; // No longer parking
> Also, initialise car_time to zero, and increment it in the vehicle
> ticker1().
>>> ...as well as all the new function and parameter settings.
>> I haven't seen a function call / parameter setup utility -- is that a
>> hidden feature, or no UI yet, or a bug on my device?
> The icon is not ideal at the moment. Go to settings, then the little
> pencil icon to go to the car settings, then press the icon that looks
> like a joystick in the top right. That is the control menu. From
> there, we have Features and Parameters.
> On 24 Jan, 2013, at 10:29 PM, Michael Balzer wrote:
>> Mark,
>> a short report for my HTC Desire HD / Android 2.3.5:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130129/f1ad8d4e/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130129/f1ad8d4e/attachment-0002.vcf>
