[Ovmsdev] OVMS Developers Document
Fri Jan 11 23:41:46 HKT 2013
Mark,
excellent! Should save quite some time for Nikolay and those to come. My
document can be removed from the repository, nothing left in there.
My part includes an sprintf() example... I now recommend replacing that
and also adding a "No sprintf()" section. I'm pretty sure we should
totally avoid using that function family from now on, I've had not a
single crash since removing the last sprintf() call. The section could
include a simple guide on the stp_*() functions.
Also, some guide and examples on using the framework network functions
would be good. E.g. how to send an SMS, a MSG, buffers & status
variables to use, size limits etc..
I think the raw document file format doesn't matter as long as
OpenOffice can at least read it and we provide PDFs.
Btw: from writing the Twizy user guide, I got the impression a common
setup/network configuration guide separated from the Tesla guide could
make sense. So we would have one common user guide plus the vehicle
specific guides. Some parts I included in the Twizy guide could also be
moved to the common guide, i.e. the "dry run" section.
Am 11.01.2013 15:09, schrieb Mark Webb-Johnson:
> I've put together a first-draft of the OVMS developers document.
> Something to document, at a high-level, the OVMS code, to make it
> easier to extend and use it (in particular for those writing vehicle
> modules).
> You can find it on github, in the docs directory.
> The PDF is here:
> https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/OVMS_Development.pdf?raw=true
> The DOCX document is here:
> https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/OVMS_Development.docx?raw=true
> Note that the code development hints and tools section comes from
> Michael B's Firmware-Development.odt document in the same directory.
> Thanks, Michael.
> The vehicle side of this document is mostly complete. What is missing
> are some conclusions, and the server and apps parts. But, it is good
> enough to be used for vehicle side today. I will keep working on it.
> If you see anything wrong, or think some parts of need expanding /
> removing, please let me know.
> P.S. Like other OVMS documents, it is in DOCX and PDF format. Not
> because I like it, but because I've given up ;-) It pains me every
> time I start Microsoft Word on my Mac. Some day, the world will be rid
> of Microsoft Office, just not today.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130111/b8f8a798/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130111/b8f8a798/attachment-0002.vcf>
