[Ovmsdev] OVMS OBDII Cables now available
Fri Jan 4 00:16:51 HKT 2013
Mark,
my cable sample was delivered today. Works great, length and connectors
are perfect for the Twizy.
I also had no customs trouble this time, thanks to Fasttech and their
big fat value sticker :-)
Am 29.12.2012 17:01, schrieb Mark Webb-Johnson:
> I like it. Looks neat.
> Really glad I found that right-angled OBDII connector - although a
> little bit more money, I think it makes a big difference given where
> the OBDII ports are in most vehicles.
> On 29 Dec, 2012, at 8:40 PM, mikeljo at me.com <mailto:mikeljo at me.com> wrote:
>> Hi mark,
>> nothing with customs. ;-)
>> I think the quality is ok.
>> The length is for normal use ok, but for my development is a little
>> bit short. My module is in the moment behind the Driver seat. This is
>> NO Problem!!
>> When the module is installed in the dashbord the length is ok.
>> Here is a Pic:
>> <IMG_1087.jpeg>
>> With the cable to the side, it is out of the way. Secure from my feet.
>> Bye
>> michael
>> Am 28.12.2012 um 17:40 schrieb Mark Webb-Johnson
>> <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>>> Michael,
>>> Thanks for testing this. I hope you didn't get too much hassle at
>>> customs.
>>> What do you think of the cable? Good enough for the job?
>>> On 28 Dec, 2012, at 8:14 PM, mikeljo at me.com <mailto:mikeljo at me.com>
>>> wrote:
>>>> Hi all,
>>>> Cable received.
>>>> Tested and it Works.
>>>> Bye
>>>> Michael
>>>> Am 19.12.2012 um 09:20 schrieb Mark Webb-Johnson
>>>>> We received the cables yesterday, and they look good. The factory
>>>>> seems to have done a good job. I tested 5 - all ok - and even put
>>>>> one in my wife's Nissan to power up an OVMS module. Now, if only
>>>>> her car had a can bus :-(
>>>>> OVMS vehicle cables for connection to can-bus equipped OBDII
>>>>> vehicles are now available from our FastTech logistics partner.
>>>>> You can find them here:
>>>>> OVMS OBDII Cable @FastTech
>>>>> <http://www.fasttech.com/products/0/10000001/1139300>
>>>>> This cable connects the OVMS module to the vehicle CAN bus, via
>>>>> the industry standard OBDII socket. It is 1 metre in length, and
>>>>> uses a right-angle OBDII plug (J1962-M) to help with cable
>>>>> management and routing.
>>>>> The cable is intended to be used in Renault Twizy, Chevy Volt,
>>>>> Opel/Vauxhall Ampera, and other cars using OBDII connectors.
>>>>> *OVMS OBDII Cable Pinout*
>>>>> J1962-M   DB9-F   Signal
>>>>> 4         3       Chassis/Power GND
>>>>> 6         7       CAN-H
>>>>> 14        2       CAN-L
>>>>> 16        9       +12V Vehicle Power
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130103/bc40a181/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130103/bc40a181/attachment-0002.vcf>
