[Ovmsdev] sprintf / crashes
Thu Jan 3 07:57:21 HKT 2013
Mark,
bumped.
The time stamp is not mine, I just copied the C32 reply. The original
msg format is simply...
MP-0 H*-OVM-DebugCrash,0,86400
,<firmware_version>/<vehicle_type><vehicle_version>/V<hardware_version>
,<crashcnt>,<crashreason>,<checkpoint>
The GPS log msg is...
MP-0 HRT-GPS-Log,<car_odometer>,86400
,<car_latitude>,<car_longitude>,<car_altitude>,<car_direction>
,<car_speed>,<car_gpslock>,<car_stale_gps>,<net_sq>
-- so, no Twizy specific data in there.
Am 03.01.2013 00:43, schrieb Mark Webb-Johnson:
> Michael,
> Looks good. Not sure if we need date/time (the record is stamped when
> we recieve it, but no harm if easy). You can bump version to 2.2.2.
> I'll have a look at the GPS logger. It sounds useful.
> Regards, Mark
> On 3 Jan, 2013, at 3:18 AM, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
>> Mark,
>> master merge done. Hm... maybe I should have increased the firmware
>> version on this... as we've got new functionality, to 2.2.1?
>> Following your suggestion I changed the DebugCrash msg to a more
>> generic and extendable format including the version information.
>> Example entry:
>> MP-0 c32,0,6,6,*-OVM-DebugCrash,2013-01-02
>> 18:33:48,0,2.1.1/RT2.5/V2,0,0000,20
>> Btw: I think the GPS logger could also become a standard function.
>> Besides producing nice tracks it's useful to test different antennas
>> and antenna positioning. Maybe the send rate needs more
>> configurability, it currently logs once per minute or every 5 seconds
>> if streaming is enabled.
>> Am 02.01.2013 02:19, schrieb Mark Webb-Johnson:
>>> Michael,
>>> Not too surprising, and I think your approach is good. The main
>>> limiting factor we have is RAM, and doing any sort of big buffering
>>> at the framework level will be hard. I think it is better to limit
>>> at the module level (as you have done).
>>> It looks good for a master merge.
>>> Regards, Mark
>>> On 2 Jan, 2013, at 4:37 AM, Michael Balzer wrote:
>>>> Mark,
>>>> transparent chunk splitting seems to be non-trivial, so I split my
>>>> data transfers. Everything's working fine again, so I'll merge into
>>>> the master next if you don't object.
>>>> Btw, AT+CIPSEND? gave me 1460 bytes, so that's supposed to be the
>>>> size limit we should keep in mind until we find a better solution.
>>>> @Nikolay: please note, that's the total size that can be sent
>>>> within one net_msg_start() ... net_msg_send(), the buffer size
>>>> (net_scratchpad) further limits a single MSG line to currently 199
>>>> bytes max.
>>>> Regards,
>>>> Michael
>>>> Am 31.12.2012 16:23, schrieb Michael Balzer:
>>>>> Mark,
>>>>> I think I found my link dropping problem: scanning a diag log I
>>>>> took, I found out CIPSEND will fail with a plain "ERROR" if the
>>>>> data size exceeds about 1500 bytes. I guess that's either the
>>>>> SIM908 buffer size or the max network packet size. I thought the
>>>>> SIM908 would handle dividing data into packets as needed. The
>>>>> SIM908 manual mentions the max packet size depends on network
>>>>> status and should be queried by "AT+CIPSEND?". After the overrun
>>>>> net_state_activity() will not recognize "ERROR" to terminate the
>>>>> pending msg, so will run into the timeout and start a network
>>>>> re-init.
>>>>> My battery status data exceeds 1500 bytes on first run and later
>>>>> on if enough cells need updates. I'll think about how to split up
>>>>> data packets into multiple CIPSENDs. Would be nice if the net
>>>>> functions take care of this transparently.
>>>>> A secondary issue turned up from the diag log: the SIM908 crashed
>>>>> in the middle of a CIPSEND command while the module continued to
>>>>> run normally. The module still thought it's in NET_STATE_READY, so
>>>>> did not re-initalize the modem. The connection could then be
>>>>> established on the next CIPSTART, but the complete INIT stuff had
>>>>> not been done. So it seems independant SIM908 resets need to be
>>>>> handled as well, and they can occur anytime. I'll see if I can
>>>>> solve that too.
>>>>> Regards,
>>>>> Michael
>>>>> Am 30.12.2012 15:42, schrieb Michael Balzer:
>>>>>> I hesitate to merge into the master because I currently have link
>>>>>> / connectivity problems, especially during driving. I introduced
>>>>>> a GPS logging to optimize my antenna positions and managed to get
>>>>>> some really nice tracks three days ago, so I don't think this is
>>>>>> related to my changes... but I'm not 100% sure. I tried different
>>>>>> antenna positions and another GSM network, but the connection
>>>>>> keeps dropping when moving the car, and GPS position updates need
>>>>>> minutes. Could be weather conditions ...or some tricky race
>>>>>> condition bug?
>>>>> OvmsDev mailing list
>>>> <dexter.vcf>_______________________________________________
>> <dexter.vcf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130103/cdd112e2/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130103/cdd112e2/attachment-0002.vcf>
