[Ovmsdev] Volt/Ampera
Fri Jan 18 20:43:04 HKT 2013
OK. Code committed.
On 18 Jan, 2013, at 4:37 PM, Johannes Güntert <info at opel-ampera-forum.de> wrote:
> Mark,
> yes, it's 0x7e4... and the displayed temperature is xx/2 - 40
> Johannes
> Von meinem iPad gesendet
> Am 18.01.2013 um 09:18 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>> Michael,
>> Is the request ID 0x7e4, and do you have a trace of this? is it just a 1 byte response, with the following range:
>> 0/2 - 40 = -40 celcius
>> 255/2 - 40 = +87.5 celcius
>> The other source listed this as:
>> "*H2 Outside Temp Filtered", "OAT Filtered","22801F","((A-40)/2)",-20,50,"C", 7E4
>> Which is slightly different. For example byte value 100 gives:
>> (100/2) - 40 = +10 celcius
>> or (100-40)/2 = +30 celcius
>> On 18 Jan, 2013, at 2:35 PM, Michael Jochum wrote:
>>> Temp = 801f / 2 - 40
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130118/8add8e4e/attachment.html>
