[Ovmsdev] Volt/Ampera
Johannes Güntert
info at opel-ampera-forum.de
Fri Jan 18 16:37:41 HKT 2013
Mark,
yes, it's 0x7e4... and the displayed temperature is xx/2 - 40
Johannes
Von meinem iPad gesendet
Am 18.01.2013 um 09:18 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> Michael,
> Is the request ID 0x7e4, and do you have a trace of this? is it just a 1 byte response, with the following range:
> 0/2 - 40 = -40 celcius
> 255/2 - 40 = +87.5 celcius
> The other source listed this as:
> "*H2 Outside Temp Filtered", "OAT Filtered","22801F","((A-40)/2)",-20,50,"C", 7E4
> Which is slightly different. For example byte value 100 gives:
> (100/2) - 40 = +10 celcius
> or (100-40)/2 = +30 celcius
> On 18 Jan, 2013, at 2:35 PM, Michael Jochum wrote:
>> Temp = 801f / 2 - 40
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130118/c3c768d5/attachment.html>
