[Ovmsdev] ODBII source
Fri Feb 22 10:21:08 HKT 2013
Nikki,
I've looked at some of those NL thread discussions on can bus, and it seems strange. Normally in such cars, the core data is forwarded on to the master can bus (for diagnostic tools, etc). It would be surprising if the NL did not have something as fundamental as SOC on the primary OBDII connector can bus.
Do you know if anyone has tried requesting the standard OBDII fuel level PID:
TX: 0x7DF 02 01 2F 00 00 00 00 00
RX: 0x7E[8-F] 03 41 2F XX 00 00 00 00 [with XX being fuel level % XX*100/255]
It might be worth a try...
On 22 Feb, 2013, at 12:02 AM, Nikki Gordon-Bloomfield wrote:
> Guys,
> Does anyone have a good parts source for ODBII connectors? I'll need to make a special one for the Leaf, since the CAN bus we need is on different pints to the ODBII-OVMS cable I already have.
> Any tips for a good quality ODBII connector with solder tabs?
> Cheers,
> Nikki.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130222/76fdede9/attachment.htm>
