[Ovmsdev] Nissan Leaf
Tue Dec 17 22:59:03 HKT 2013
Robert,
Something like one of these:
http://m.ebay.co.uk/sch/i.html?kw=Obdii+y+cable&isNewKw=1&pgn=1&epp=24&mfs=GOCLK&acimp=0&itemId=&cnm=&cid=&sqp=obdii+y+cable&_trksid=p2056088.m2428.l1313.TR0.TRC0.Xobdii+y+cable
http://www.amazon.co.uk/gp/aw/s/ref=is_box_?k=Obdii+y+cable
Something to plug into the car obdii then give you two sockets - one for the logger and the other for leafspy.
P.S. Probably best to give me 1 log file first, to make sure everything is ok.
> On 17 Dec, 2013, at 10:42 pm, Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk> wrote:
> Hi Mark,
> Great news and thanks for tackling it even though it was hard work.
> So in summary there is
> testing of first build - Nikki do you want to do this ?
> getting logs
> without T connector - Rob to do
> with T connector - Rob once got a connector
> Which T connector would you recommend ?
> Rob
> ---- On Tue, 17 Dec 2013 15:16:04 +0100 Mark Webb-Johnson<mark at webb-johnson.net> wrote ----
> Attached is a first-run at Nissan Leaf support, with a few values read from the bus passively:
> Speed
> Headlight status
> Park / Drive status
> SOC
> I’ve also pushed this to github (along with a large number of other small changes).
> The Nissan Leaf support is proving really hard for me. I don’t have the car, or much CAN bus data, and the public documentation is contradictory and incomplete. End result is that I am just guessing, and completely unable to test my guesses.
> Anyway, please try it and let me know if any of those figures show up with any sense of accuracy at all.
> Going forward, I really need some CAN bus dumps from a Nissan Leaf. Specifically:
> Car idle
> Car plugged in and charge started
> Car charging
> Charge interrupted
> Driving
> Driving as close to a constant speed of 10 kph as possible
> Driving as close to a constant speed of 20 kph as possible
> Driving as close to a constant speed of 30 kph as possible
> Car parked, but on
> Car parked, coming out of park into drive gear
> Car stopped, coming out of drive gear into park
> Car in park gear, then handbrake applied
> For each of those, both with and without a T connector and LeafSpy running would be helpful.
> I’m guessing the logs can be gotten from monitor-all mode with an OBDII adaptor. There is not too much data on the can bus and that should be fast enough.
> If anyone can help with the above, please let me know.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131217/9ab90b07/attachment.htm>
