[Ovmsdev] Open Vehicle 3.2.1 (20131211) is now available
Rolf Welde Skeie
rwskeie at gmail.com
Wed Dec 11 20:07:18 HKT 2013
I can confirm that:
- I got an email
- I was able to download the app and install it
- I was able to change my default car picture to a Think City (horaay)
I have noticed a couple of changes which might not be intended:
- map default zoom level too zoomed in
- when in map view horizontal wipe does not go to the next menu item
(Messages), it only moves the map about.
- the Think images need a bit of photoshopping to remove the white border.
I guess I should start putting stuff in bugzilla or something..
Or even better, fix them :)
Thanks Mark for getting me "into the loop".
Best regards
Rolf
On 12/11/2013 12:49 PM, Mark Webb-Johnson wrote:
> I’ve just confirmed your join (it seems to require that). Can you try again - you should have got an eMail with the link.
> On 11 Dec, 2013, at 7:47 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
>> Hmm, after using the last two links you sent I'm now a member of the "Open Vehicles" and "Android Testers" teams, but there are no apps available.?.. (tried both compatible and noncompatible).
>> More tricks up your sleeve? :)
>> Regards
>> Rolf
>> On 12/11/2013 12:40 PM, Mark Webb-Johnson wrote:
>>> Sorry, still getting used to the new Android testflightapp. This link
>>> may be better:
>>> http://tflig.ht/v8INxA
>>> On 11 Dec, 2013, at 7:32 pm, Mark Webb-Johnson <mark at webb-johnson.net
>>> <mailto:mark at webb-johnson.net>> wrote:
>>>> For those not already in testflightapp, the following recruitment URL
>>>> should let you sign-up:
>>>> http://tflig.ht/18Bho0d
>>>> Regards, Mark.
>>>> On 11 Dec, 2013, at 5:25 pm, Mark Webb-Johnson <mark at webb-johnson.net
>>>>> A good day.
>>>>> OVMS Android App v3.2.1 is now released to beta test. You can get it
>>>>> from testflightapp:
>>>>> http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNzcwMg/
>>>>> We’re using TestFlightApp for both iOS and Android Apps, so it would
>>>>> be helpful if you could register there. If you do, you’ll get
>>>>> notified of new builds as and when they are released.
>>>>> As with the iOS App, we’ve had sponsorship and support from Zero
>>>>> Carbon World for this:
>>>>> Charging station integration and information provided by Zero
>>>>> Carbon World (http://www.zerocarbonworld.org/open-charge-map) and
>>>>> the Open Charge Map project (www.openchargemap.org
>>>>> <http://www.openchargemap.org/>).
>>>>> Let me have feedback / problems via testflightapp or here. It is a
>>>>> beta #1 build, but is functionally complete. The only known issue is
>>>>> a 20 second delay when a new car is setup (or the first time the app
>>>>> is run), for charge station data to be downloaded.
>>>>> Regards, Mark.
>>>>>> TestFlight » Beta Testing On The Fly
>>>>>> *Open Vehicle*
>>>>>> Version 3.2.1 (20131211) INSTALL
>>>>>> <http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ>
>>>>>> (open this email on your Android 2.3+ Device and click the install
>>>>>> button)
>>>>>> *What's New*
>>>>>> v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1
>>>>>> * 67dd173 Disable two-finger rotation gesture for map
>>>>>> * 79b70dd Dont show undefined number of charging points as "null"
>>>>>> * f813df7 Revise clustering factors, to improve usability choices
>>>>>> * d1786ca Tidy up layout of setting dialog
>>>>>> * d37d9c7 OCM integration, rough draft
>>>>>> *Details*
>>>>>> *Platform:* Android
>>>>>> *Version:* 3.2.1 (20131211)
>>>>>> *Team:* Open Vehicles
>>>>>> *Release Date:* December 11, 2013
>>>>>> *Size:* 13.4 MB
>>>>> OvmsDev mailing list
>> Rolf Welde Skeie
>> Solåsen 27, 5223 Nesttun, Norway
>> +47 92403016 / rwskeie at gmail.com
Rolf Welde Skeie
