[Ovmsdev] Open Vehicle 3.2.1 (20131211) is now available
Wed Dec 11 20:13:21 HKT 2013
Fix would be good! Github pulls accepted :-)
> - map default zoom level too zoomed in
We tried to put it close to the iOS version, but maybe both are too aggressive. It is a fairly simple change I think.
> - when in map view horizontal wipe does not go to the next menu item (Messages), it only moves the map about.
On my nexus 4, I need to swipe from just off the side of the screen, and not too fast. I think this is part of the ActionBarSherlock framework.
> - the Think images need a bit of photoshopping to remove the white border.
I wouldn’t worry about this too much, but you are welcome to make the fix. I am re-working that entire framework to use base layer + colour layer + mask to generate all the different car images from one.
Any help you, or anyone, can give to this would be most appreciated. This is beta #1, and the changes made to get OCM integration done have been quite drastic (most notable upgrading to maps api v2). I am aware that the translations will need to be added to, but that can be left until we are a bit later in this beta process.
On 11 Dec, 2013, at 8:07 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
> I can confirm that:
> - I got an email
> - I was able to download the app and install it
> - I was able to change my default car picture to a Think City (horaay)
> I have noticed a couple of changes which might not be intended:
> I guess I should start putting stuff in bugzilla or something..
> Or even better, fix them :)
> Thanks Mark for getting me "into the loop".
> Best regards
>  Rolf
> On 12/11/2013 12:49 PM, Mark Webb-Johnson wrote:
>> I’ve just confirmed your join (it seems to require that). Can you try again - you should have got an eMail with the link.
>> On 11 Dec, 2013, at 7:47 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
>>> Hmm, after using the last two links you sent I'm now a member of the "Open Vehicles" and "Android Testers" teams, but there are no apps available.?.. (tried both compatible and noncompatible).
>>> More tricks up your sleeve? :)
>>> Regards
>>>  Rolf
>>> On 12/11/2013 12:40 PM, Mark Webb-Johnson wrote:
>>>> Sorry, still getting used to the new Android testflightapp. This link
>>>> may be better:
>>>>    http://tflig.ht/v8INxA
>>>> Regards, Mark.
>>>> On 11 Dec, 2013, at 7:32 pm, Mark Webb-Johnson <mark at webb-johnson.net
>>>> <mailto:mark at webb-johnson.net>> wrote:
>>>>> For those not already in testflightapp, the following recruitment URL
>>>>> should let you sign-up:
>>>>>    http://tflig.ht/18Bho0d
>>>>> Regards, Mark.
>>>>> On 11 Dec, 2013, at 5:25 pm, Mark Webb-Johnson <mark at webb-johnson.net
>>>>>> A good day.
>>>>>> OVMS Android App v3.2.1 is now released to beta test. You can get it
>>>>>> from testflightapp:
>>>>>>    http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNzcwMg/
>>>>>> We’re using TestFlightApp for both iOS and Android Apps, so it would
>>>>>> be helpful if you could register there. If you do, you’ll get
>>>>>> notified of new builds as and when they are released.
>>>>>> As with the iOS App, we’ve had sponsorship and support from Zero
>>>>>> Carbon World for this:
>>>>>>    Charging station integration and information provided by Zero
>>>>>>    Carbon World (http://www.zerocarbonworld.org/open-charge-map) and
>>>>>>    the Open Charge Map project (www.openchargemap.org
>>>>>>    <http://www.openchargemap.org/>).
>>>>>> Let me have feedback / problems via testflightapp or here. It is a
>>>>>> beta #1 build, but is functionally complete. The only known issue is
>>>>>> a 20 second delay when a new car is setup (or the first time the app
>>>>>> is run), for charge station data to be downloaded.
>>>>>> Regards, Mark.
>>>>>>> TestFlight » Beta Testing On The Fly
>>>>>>> 	*Open Vehicle*
>>>>>>> Version 3.2.1 (20131211) 	INSTALL
>>>>>>> <http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ>
>>>>>>> (open this email on your Android 2.3+ Device and click the install
>>>>>>> button)
>>>>>>> *What's New*
>>>>>>> v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1
>>>>>>> * 67dd173 Disable two-finger rotation gesture for map
>>>>>>> * 79b70dd Dont show undefined number of charging points as "null"
>>>>>>> * f813df7 Revise clustering factors, to improve usability choices
>>>>>>> * d1786ca Tidy up layout of setting dialog
>>>>>>> * d37d9c7 OCM integration, rough draft
>>>>>>> *Details*
>>>>>>> *Platform:* 	Android
>>>>>>> *Version:* 	3.2.1 (20131211)
>>>>>>> *Team:* 	Open Vehicles
>>>>>>> *Release Date:* 	December 11, 2013
>>>>>>> *Size:* 	13.4 MB
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>> Rolf Welde Skeie
>>> Solåsen 27, 5223 Nesttun, Norway
>>> +47 92403016 / rwskeie at gmail.com
> Rolf Welde Skeie
