[Ovmsdev] Problem creating an array for Think City
Sat Aug 24 14:44:11 HKT 2013
Is it possible to  use the net.h net_req_notification_error() system. That can be used to send an error code, and associated data, to the server. The server applies a lookup table to convert the error code to error message (per vehicle model), and then sends the alert out as a push notification to the Apps.
On 22 Aug, 2013, at 4:30 AM, Håkon Markussen <hakon.markussen at gmail.com> wrote:
> Hi,
> I'm trying to create a fault/error SMS function for the vehicle_thinkcity.c
> The idea is making a two columns array, where the first column keeps different alarm messages available, while the second column keeps the state-variables of the corresponding error.
> Later on, only active errors, which has it's state-variable flag set, will be sent in the SMS (and the number of active errors).
> Unfortunately my code did not work, and I therefor ask you for some help.
> The code is currently:
> void vehicle_thinkcity_fault_prepmsg(void)
>   rom char vehicle_thinkcity_fault_txttable[][] =
>     "MnyFailCel", // -> tc_bit_manyfailedcells;
>     "Crash", // -> tc_bit_crash;
>     "GenErr", // -> tc_bit_generalerr;
>     "IsoErr", // -> tc_bit_isoerr;
>     "IntIso", // -> tc_bit_intisoerr;
>     "ExtIso", // -> tc_bit_extisoerr;
>     "ThermIso", // -> tc_bit_thermalisoerr;
>     "EmgEPO", // -> tc_bit_epoemerg;
>     "ChgWaitTemp", // -> tc_bit_chgwaittemp;
>     "ReachEOC", // -> tc_bit_reacheocplease;
>     "WaitOkTpDcg", // -> tc_bit_waitoktmpdisch;
>     "CrgWaitTp2", // -> tc_bit_chgwaitttemp2;
>     "NoChgCur", // -> tc_bit_nochgcurr;
>     "ChgOverVolt", // -> tc_bit_chgovervolt;
>     "ChgOverCur", // -> tc_bit_chgovercurr;
>     rom char vehicle_thinkcity_fault_vartable[] =
>     tc_bit_manyfailedcells,
>     tc_bit_crash,
>     tc_bit_generalerr,
>     tc_bit_isoerr,
>     tc_bit_intisoerr,
>     tc_bit_extisoerr,
>     tc_bit_thermalisoerr,
>     tc_bit_epoemerg,
>     tc_bit_chgwaittemp,
>     tc_bit_reacheocplease,
>     tc_bit_waitoktmpdisch,
>     tc_bit_chgwaitttemp2,
>     tc_bit_nochgcurr,
>     tc_bit_chgovervolt,
>     tc_bit_chgovercurr
>   char *s;
>   int k;
>   int errcount = 0 ;
>   s = strchr(net_scratchpad, 0);
>   s = stp_rom(s, "Act err:");
>    //additional info for error-print
>   if (tc_pack_failedcells != 0)
>     s = stp_i(s, "\rFailCel:", tc_pack_failedcells);
> 	errcount++;
>    // end additional info
>   for (k = 0; vehicle_thinkcity_fault_txttable[k][0] != 0; k++)
>     if (vehicle_thinkcity_fault_vartable[k] != 0)
>       s = stp_i(s, "\r", vehicle_thinkcity_fault_txttable[k]);
>       k++;
> 	errcount++;
>   s = stp_i(s, "\rTot err: ", errcount);
> Best regards
> Håkon
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130824/8df99a08/attachment.htm>
