[Ovmsdev] Problem creating an array for Think City
Håkon Markussen hakon.markussen at gmail.com
Thu Aug 22 04:30:20 HKT 2013
Hi,
I'm trying to create a fault/error SMS function for the vehicle_thinkcity.c
The idea is making a two columns array, where the first column keeps
different alarm messages available, while the second column keeps the
state-variables of the corresponding error.
Later on, only active errors, which has it's state-variable flag set, will
be sent in the SMS (and the number of active errors).
Unfortunately my code did not work, and I therefor ask you for some help.
*The code is currently:*
*void vehicle_thinkcity_fault_prepmsg(void)*
*  rom char vehicle_thinkcity_fault_txttable[][] = *
*    "MnyFailCel", // -> tc_bit_manyfailedcells;*
*    "Crash", // -> tc_bit_crash;*
*    "GenErr", // -> tc_bit_generalerr;*
*    "IsoErr", // -> tc_bit_isoerr;*
*    "IntIso", // -> tc_bit_intisoerr;*
*    "ExtIso", // -> tc_bit_extisoerr;*
*    "ThermIso", // -> tc_bit_thermalisoerr;*
*    "EmgEPO", // -> tc_bit_epoemerg;*
*    "ChgWaitTemp", // -> tc_bit_chgwaittemp;*
*    "ReachEOC", // -> tc_bit_reacheocplease;*
*    "WaitOkTpDcg", // -> tc_bit_waitoktmpdisch;*
*    "CrgWaitTp2", // -> tc_bit_chgwaitttemp2;*
*    "NoChgCur", // -> tc_bit_nochgcurr;*
*    "ChgOverVolt", // -> tc_bit_chgovervolt;*
*    "ChgOverCur", // -> tc_bit_chgovercurr;*
*    rom char vehicle_thinkcity_fault_vartable[] = *
*    tc_bit_manyfailedcells,*
*    tc_bit_crash,*
*    tc_bit_generalerr,*
*    tc_bit_isoerr,*
*    tc_bit_intisoerr,*
*    tc_bit_extisoerr,*
*    tc_bit_thermalisoerr,*
*    tc_bit_epoemerg,*
*    tc_bit_chgwaittemp,*
*    tc_bit_reacheocplease,*
*    tc_bit_waitoktmpdisch,*
*    tc_bit_chgwaitttemp2,*
*    tc_bit_nochgcurr,*
*    tc_bit_chgovervolt,*
*    tc_bit_chgovercurr*
*  char *s;*
*  int k;*
*  int errcount = 0 ;*
*  s = strchr(net_scratchpad, 0);*
*  s = stp_rom(s, "Act err:");*
*   //additional info for error-print*
*  if (tc_pack_failedcells != 0)*
*    s = stp_i(s, "\rFailCel:", tc_pack_failedcells);*
* errcount++;*
*   // end additional info  *
*  for (k = 0; vehicle_thinkcity_fault_txttable[k][0] != 0; k++)*
*    if (vehicle_thinkcity_fault_vartable[k] != 0)*
*      s = stp_i(s, "\r", vehicle_thinkcity_fault_txttable[k]);*
*      k++;*
* errcount++;*
*  s = stp_i(s, "\rTot err: ", errcount);*
Best regards
Håkon
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130821/4c34ed0b/attachment.htm>
