[Ovmsdev] Problem creating an array for Think City
Sat Aug 24 14:44:11 HKT 2013
Is it possible to use the net.h net_req_notification_error() system. That can be used to send an error code, and associated data, to the server. The server applies a lookup table to convert the error code to error message (per vehicle model), and then sends the alert out as a push notification to the Apps.
On 22 Aug, 2013, at 4:30 AM, Håkon Markussen <hakon.markussen at gmail.com> wrote:
> Hi,
> I'm trying to create a fault/error SMS function for the vehicle_thinkcity.c
> The idea is making a two columns array, where the first column keeps different alarm messages available, while the second column keeps the state-variables of the corresponding error.
> Later on, only active errors, which has it's state-variable flag set, will be sent in the SMS (and the number of active errors).
> Unfortunately my code did not work, and I therefor ask you for some help.
> The code is currently:
> void vehicle_thinkcity_fault_prepmsg(void)
> rom char vehicle_thinkcity_fault_txttable[][] =
> "MnyFailCel", // -> tc_bit_manyfailedcells;
> "Crash", // -> tc_bit_crash;
> "GenErr", // -> tc_bit_generalerr;
> "IsoErr", // -> tc_bit_isoerr;
> "IntIso", // -> tc_bit_intisoerr;
> "ExtIso", // -> tc_bit_extisoerr;
> "ThermIso", // -> tc_bit_thermalisoerr;
> "EmgEPO", // -> tc_bit_epoemerg;
> "ChgWaitTemp", // -> tc_bit_chgwaittemp;
> "ReachEOC", // -> tc_bit_reacheocplease;
> "WaitOkTpDcg", // -> tc_bit_waitoktmpdisch;
> "CrgWaitTp2", // -> tc_bit_chgwaitttemp2;
> "NoChgCur", // -> tc_bit_nochgcurr;
> "ChgOverVolt", // -> tc_bit_chgovervolt;
> "ChgOverCur", // -> tc_bit_chgovercurr;
> rom char vehicle_thinkcity_fault_vartable[] =
> tc_bit_manyfailedcells,
> tc_bit_crash,
> tc_bit_generalerr,
> tc_bit_isoerr,
> tc_bit_intisoerr,
> tc_bit_extisoerr,
> tc_bit_thermalisoerr,
> tc_bit_epoemerg,
> tc_bit_chgwaittemp,
> tc_bit_reacheocplease,
> tc_bit_waitoktmpdisch,
> tc_bit_chgwaitttemp2,
> tc_bit_nochgcurr,
> tc_bit_chgovervolt,
> tc_bit_chgovercurr
> char *s;
> int k;
> int errcount = 0 ;
> s = strchr(net_scratchpad, 0);
> s = stp_rom(s, "Act err:");
> //additional info for error-print
> if (tc_pack_failedcells != 0)
> s = stp_i(s, "\rFailCel:", tc_pack_failedcells);
> errcount++;
> // end additional info
> for (k = 0; vehicle_thinkcity_fault_txttable[k][0] != 0; k++)
> if (vehicle_thinkcity_fault_vartable[k] != 0)
> s = stp_i(s, "\r", vehicle_thinkcity_fault_txttable[k]);
> k++;
> errcount++;
> s = stp_i(s, "\rTot err: ", errcount);
> Best regards
> Håkon
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130824/8df99a08/attachment.html>
