[Ovmsdev] Problem creating an array for Think City
Håkon Markussen
hakon.markussen at gmail.com
Thu Aug 22 04:30:20 HKT 2013
Hi,
I'm trying to create a fault/error SMS function for the vehicle_thinkcity.c
The idea is making a two columns array, where the first column keeps
different alarm messages available, while the second column keeps the
state-variables of the corresponding error.
Later on, only active errors, which has it's state-variable flag set, will
be sent in the SMS (and the number of active errors).
Unfortunately my code did not work, and I therefor ask you for some help.
*The code is currently:*
*void vehicle_thinkcity_fault_prepmsg(void)*
* rom char vehicle_thinkcity_fault_txttable[][] = *
* "MnyFailCel", // -> tc_bit_manyfailedcells;*
* "Crash", // -> tc_bit_crash;*
* "GenErr", // -> tc_bit_generalerr;*
* "IsoErr", // -> tc_bit_isoerr;*
* "IntIso", // -> tc_bit_intisoerr;*
* "ExtIso", // -> tc_bit_extisoerr;*
* "ThermIso", // -> tc_bit_thermalisoerr;*
* "EmgEPO", // -> tc_bit_epoemerg;*
* "ChgWaitTemp", // -> tc_bit_chgwaittemp;*
* "ReachEOC", // -> tc_bit_reacheocplease;*
* "WaitOkTpDcg", // -> tc_bit_waitoktmpdisch;*
* "CrgWaitTp2", // -> tc_bit_chgwaitttemp2;*
* "NoChgCur", // -> tc_bit_nochgcurr;*
* "ChgOverVolt", // -> tc_bit_chgovervolt;*
* "ChgOverCur", // -> tc_bit_chgovercurr;*
* rom char vehicle_thinkcity_fault_vartable[] = *
* tc_bit_manyfailedcells,*
* tc_bit_crash,*
* tc_bit_generalerr,*
* tc_bit_isoerr,*
* tc_bit_intisoerr,*
* tc_bit_extisoerr,*
* tc_bit_thermalisoerr,*
* tc_bit_epoemerg,*
* tc_bit_chgwaittemp,*
* tc_bit_reacheocplease,*
* tc_bit_waitoktmpdisch,*
* tc_bit_chgwaitttemp2,*
* tc_bit_nochgcurr,*
* tc_bit_chgovervolt,*
* tc_bit_chgovercurr*
* char *s;*
* int k;*
* int errcount = 0 ;*
* s = strchr(net_scratchpad, 0);*
* s = stp_rom(s, "Act err:");*
* //additional info for error-print*
* if (tc_pack_failedcells != 0)*
* s = stp_i(s, "\rFailCel:", tc_pack_failedcells);*
* errcount++;*
* // end additional info *
* for (k = 0; vehicle_thinkcity_fault_txttable[k][0] != 0; k++)*
* if (vehicle_thinkcity_fault_vartable[k] != 0)*
* s = stp_i(s, "\r", vehicle_thinkcity_fault_txttable[k]);*
* k++;*
* errcount++;*
* s = stp_i(s, "\rTot err: ", errcount);*
Best regards
Håkon
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130821/4c34ed0b/attachment-0001.html>
