[Ovmsdev] Release Firmware
Wed Apr 17 08:51:48 HKT 2013
> I‘ve installed the new 2.3.2 firmware. Everything works stable and the ODO Values are more or less okay.
Fantastic - thanks for helping to test this.
> Is there one new alert? 882 (00000004) - Before starting, charge port door must be closed.
Added to my collection :-)
> How can I disable the push messages ? Feature 14: VALUE?
Yes, car bits feature 14, add 8 to the value (bit #3) to suppress vehicle alerts via push notification.
On 17 Apr, 2013, at 2:28 AM, 911carrera4 wrote:
> Mark
> Piotr
> Von: ovmsdev-bounces at lists.teslaclub.hk [mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Webb-Johnson
> Gesendet: Dienstag, 16. April 2013 09:59
> An: OVMS Developers
> Betreff: Re: [Ovmsdev] Release Firmware
> The message occurred at:
> 2013-04-16 00:56:15.341898 -0400 info main: #22 C SILVERARROW rx msg P ETR2N,1174,16384
> (time zone -0400 = 4 hours west of GMT)
> Alert #1174 is close to the other alerts for driving (such as unsafe gear shift, tow mode not available, etc), but the time seems very early in the morning. +0100 would be just before 6am!
> On 16 Apr, 2013, at 3:26 PM, 911carrera4 wrote:
> no, there was no alert on the SILVERARROW VSD screen.
> Von meinem iPhone gesendet
> Am 16.04.2013 um 09:10 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> Yes, that is a new feature - the VDS alerts are relayed as PUSH notifications to the smartphone. Useful to give more information on charge interrupted alerts, as well as other vehicle problems.
> The alert from SILVERARROW (1174) is new. Do you know what error message the car was saying at the time (it would be a pop-up window on the VDS)?
> On 16 Apr, 2013, at 3:05 PM, 911carrera4 wrote:
> mark, this mornig me and karin got two new alerts we didn't use to get with the previous versions of firmware<image.png>
> <image.png>
> Piotr
> Am 16.04.2013 um 03:09 schrieb Tom Saxton <tom at idleloop.com>:
> I can't believe I missed that! Before sending you the diff, I switched my
> module to km and tested the status message. I verified that the ideal and
> estimated range changed values and displayed as expected, and that the
> odometer was shown in km, but didn't catch that it was still showing the
> value for miles.
> I saw Pierre's message just a few minutes ago and did a git pull to look at
> the code and couldn't see what was wrong. I was thinking it had to be a
> compiler bug. Then I saw your message that you had just fixed it, and looked
> back at the history to see what the bug was.
> I have the firmware update page ready to update.
> Tom
> on 4/15/13 5:34 PM, Mark Webb-Johnson wrote:
> Tom,
> I think the SMS STAT odometer bug is serious enough to require a new build.
> The good news is that seems to be it, and the fix is simple.
> I'll build v1.3.2 tonight and that can be the one to announce and release.
> On 16 Apr, 2013, at 12:01 AM, Tom Saxton wrote:
> on 4/14/13 11:03 PM, Mark Webb-Johnson wrote:
> Seems to be that you and I are the only Tesla Roadsters on tmc server that
> are
> running v2.3.1 yet (not surprising, as only pre-released yesterday)
> I just put it in my v1.5 Roadster. It seems to be working fine (iPhone app
> updates, SMS stat command shows the expected values).
> I can post 2.3.1 on my firmware update page as soon as you're ready for
> that.
> For anyone who wants the firmware links:
> 2.3.1 for V1 hardware:
> https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/v2.3.1/vehicle/
> firmware/V1_production.hex
> 2.3.1 for V2 hardware:
> firmware/V2_production.hex
> Tom
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130417/007eae16/attachment.htm>
