[Ovmsdev] Release Firmware
911carrera4
911carrera4 at bluewin.ch
Wed Apr 17 02:28:49 HKT 2013
Mark
I've installed the new 2.3.2 firmware. Everything works stable and the ODO
Values are more or less okay.
Is there one new alert? 882 (00000004) - Before starting, charge port door
must be closed.
How can I disable the push messages ? Feature 14: VALUE?
Piotr
Von: ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Webb-Johnson
Gesendet: Dienstag, 16. April 2013 09:59
An: OVMS Developers
Betreff: Re: [Ovmsdev] Release Firmware
The message occurred at:
2013-04-16 00:56:15.341898 -0400 info main: #22 C SILVERARROW rx msg P
ETR2N,1174,16384
(time zone -0400 = 4 hours west of GMT)
Alert #1174 is close to the other alerts for driving (such as unsafe gear
shift, tow mode not available, etc), but the time seems very early in the
morning. +0100 would be just before 6am!
On 16 Apr, 2013, at 3:26 PM, 911carrera4 wrote:
no, there was no alert on the SILVERARROW VSD screen.
Von meinem iPhone gesendet
Am 16.04.2013 um 09:10 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
Yes, that is a new feature - the VDS alerts are relayed as PUSH
notifications to the smartphone. Useful to give more information on charge
interrupted alerts, as well as other vehicle problems.
The alert from SILVERARROW (1174) is new. Do you know what error message the
car was saying at the time (it would be a pop-up window on the VDS)?
On 16 Apr, 2013, at 3:05 PM, 911carrera4 wrote:
mark, this mornig me and karin got two new alerts we didn't use to get with
the previous versions of firmware<image.png>
<image.png>
Piotr
Am 16.04.2013 um 03:09 schrieb Tom Saxton <tom at idleloop.com>:
I can't believe I missed that! Before sending you the diff, I switched my
module to km and tested the status message. I verified that the ideal and
estimated range changed values and displayed as expected, and that the
odometer was shown in km, but didn't catch that it was still showing the
value for miles.
I saw Pierre's message just a few minutes ago and did a git pull to look at
the code and couldn't see what was wrong. I was thinking it had to be a
compiler bug. Then I saw your message that you had just fixed it, and looked
back at the history to see what the bug was.
I have the firmware update page ready to update.
Tom
on 4/15/13 5:34 PM, Mark Webb-Johnson wrote:
Tom,
I think the SMS STAT odometer bug is serious enough to require a new build.
The good news is that seems to be it, and the fix is simple.
I'll build v1.3.2 tonight and that can be the one to announce and release.
On 16 Apr, 2013, at 12:01 AM, Tom Saxton wrote:
on 4/14/13 11:03 PM, Mark Webb-Johnson wrote:
Seems to be that you and I are the only Tesla Roadsters on tmc server that
are
running v2.3.1 yet (not surprising, as only pre-released yesterday)
I just put it in my v1.5 Roadster. It seems to be working fine (iPhone app
updates, SMS stat command shows the expected values).
I can post 2.3.1 on my firmware update page as soon as you're ready for
that.
For anyone who wants the firmware links:
2.3.1 for V1 hardware:
https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/v2.3.1/vehicle/
firmware/V1_production.hex
2.3.1 for V2 hardware:
firmware/V2_production.hex
Tom
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130416/67f694a7/attachment.htm>
