[Ovmsdev] Comments on Tazzari Firmware
Sun Apr 14 22:06:46 HKT 2013
Patrick,
There shouldn't be any 'charge complete' notifications - only 'charge interrupted':
Current logic is:
          case 0x63: // Charge done/failed (depending where we came from)
            car_doors1 &= ~0x0c;    // Clear charge and pilot bits
            car_chargemode = 0;     // Standard charge mode
            car_charge_b4 = 0;      // Not required
            if (car_chargestate == 4)
              { // Charge done
            else if (car_chargestate != 21)
              { // Charge interrupted
              car_chargestate = 21;    // Charge STOPPED
              car_chargesubstate = 14; // Charge INTERRUPTED
              net_req_notification(NET_NOTIFY_CHARGE);
            break;
PID 0xFDE0 shows 8bit value 0x63 and car_chargestate != 4 and car_chargestate != 21, then we treat that as a charge interrupted and alert appropriately.
Does that seem correct? I'll have to check through the logs you made to double-check.
On 14 Apr, 2013, at 5:53 AM, Patrick Kapsch <patrick.kapsch at mac.com> wrote:
> Mark,
> Since you fixed push notifications, fully charged notification works for the Tazzari. Charge interrupt notification doesn't.
> Patrick
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130414/7709f245/attachment.htm>
