[Ovmsdev] Release Firmware
Fri Apr 12 01:33:43 HKT 2013
I think I was a bit too fast on this, Nikki, don't use that version, it
seems to have some new bug causing frequent crashes... :-(
Am 11.04.2013 19:22, schrieb Michael Balzer:
> Mark, Nikki,
> I'm currently trying to fix a last bug with the power statistics (the
> distance counter still went wrong), and I'm trying to get the 12V A/D
> conversion to work without these strange "peaks" by raising the
> automatic acquisition time. I will finish testing this ASAP or tell
> you in time before sunday.
> Nikki, I attached the latest version in case you'd like to test as well.
> Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
>> China is bugging me for final firmware for the next batch of
>> hardware. I need to get them this early next week.
>> I've committed what I need for the Tesla Roadster (and framework).
>> Last outstanding small change to make is to send CAC as 999.99,
>> rather than the current 99999, using Tom's new library function.
>> Michael B & J: can you check Twizzy and Volt/Ampera, to see if
>> everything is ok with current firmware or there is anything you need
>> changed?
>> I plan to cut release candidate for 2.3.1 on Sunday.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130411/e7788182/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130411/e7788182/attachment-0002.vcf>
