[Ovmsdev] Release Firmware
Fri Apr 12 01:22:45 HKT 2013
Mark, Nikki,
I'm currently trying to fix a last bug with the power statistics (the
distance counter still went wrong), and I'm trying to get the 12V A/D
conversion to work without these strange "peaks" by raising the
automatic acquisition time. I will finish testing this ASAP or tell you
in time before sunday.
Nikki, I attached the latest version in case you'd like to test as well.
Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
> China is bugging me for final firmware for the next batch of hardware. I need to get them this early next week.
> I've committed what I need for the Tesla Roadster (and framework). Last outstanding small change to make is to send CAC as 999.99, rather than the current 99999, using Tom's new library function.
> Michael B & J: can you check Twizzy and Volt/Ampera, to see if everything is ok with current firmware or there is anything you need changed?
> I plan to cut release candidate for 2.3.1 on Sunday.
Type: text/x-hex
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130411/c3885d9f/attachment-0002.bin>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130411/c3885d9f/attachment-0002.vcf>
