[Ovmsdev] GPS Logs (TWIZY) -- Future Feature?
Tue Apr 9 03:58:20 HKT 2013
Nikki,
I did some more stress tests and could trigger two errors with streaming
enabled. I checked the code again and maybe found a bug that could
result in connection drops in case of an exact time synchronisation
between framework and Twizy notifications (the framework could send
notifications without checking for pending sends).
I also raised the watchdog timeout to 16 seconds because there are so
many delays in the net code that we might pass the 8 seconds under
normal conditions now.
Am 08.04.2013 19:27, schrieb Michael Balzer:
> Nikki,
> that's really strange as I haven't touched the range calculation at all.
> Can you please check your feature and parameter settings, especially
> max ideal range? I sometimes (seldom) lose some of the configuration
> on flashing.
> Also please try to force an SRAM reinit by switching the vehicle type
> to some other and then back to "RT".
> Do the problems occur only in GPS streaming mode or also with normal
> update frequency?
> Thanks,
> Am 08.04.2013 18:06, schrieb Nikki Gordon-Bloomfield:
>> Hi Michael,
>> Confirmed CAN bus happily connected (ODB2), and that modules are
>> firmly affixed with good signal.
>> Attached is the BattPack.CSV file, along with the other four logs. .
>> Notice that there's a big gap where it stopped reporting and then I
>> reconnected it (That's what the reboots are in the logs: when I
>> reconnected the system after firmware installation and when I
>> reconnected to reboot it)
>> Given that it completely died for the best part of my trip, I'm
>> tempted to suggest that it was a firmware bug.
>> In addition, my Twizy now reports a range in the hundreds of miles!
>> Congratulations, you broke the laws of physics (Or we've shifted to
>> the right one too many!)
>> Nikki.
>> On 8 Apr 2013, at 16:14, Nikki Gordon-Bloomfield
>> <nikki at littlecollie.com <mailto:nikki at littlecollie.com>> wrote:
>>> Ok! I'll check when I get home!
>>> Sent from my iPhone
>>> On 8 Apr 2013, at 16:09, Michael Balzer <dexter at expeedo.de
>>> <mailto:dexter at expeedo.de>> wrote:
>>>> ...or an antenna / GSM problem, logs are sent on GSM connect also.
>>>> Am 08.04.2013 17:02, schrieb Michael Balzer:
>>>>> Nikki,
>>>>> that rather looks like some problem with your OBD2 connector (12V
>>>>> power supply), as the logs show only first boots instead of
>>>>> resets/crashes.
>>>>> Can you check that?
>>>>> I have no problem running the last version I sent.
>>>>> Thanks,
>>>>> Michael
>>>>> Am 08.04.2013 16:32, schrieb Nikki Gordon-Bloomfield:
>>>>>> Michael,
>>>>>> Here's my debug log. Any use?
>>>>>> Nikki.
>>>>>> OvmsDev mailing list
>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>> <dexter.vcf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130408/0a08ff5a/attachment.htm>
Type: text/x-hex
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130408/0a08ff5a/attachment-0002.bin>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130408/0a08ff5a/attachment-0002.vcf>
