[Ovmsdev] GPS Logs (TWIZY) -- Future Feature?
Tue Apr 9 01:27:46 HKT 2013
Nikki,
that's really strange as I haven't touched the range calculation at all.
Can you please check your feature and parameter settings, especially max
ideal range? I sometimes (seldom) lose some of the configuration on
flashing.
Also please try to force an SRAM reinit by switching the vehicle type to
some other and then back to "RT".
Do the problems occur only in GPS streaming mode or also with normal
update frequency?
Thanks,
Am 08.04.2013 18:06, schrieb Nikki Gordon-Bloomfield:
> Hi Michael,
> Confirmed CAN bus happily connected (ODB2), and that modules are
> firmly affixed with good signal.
> Attached is the BattPack.CSV file, along with the other four logs. .
> Notice that there's a big gap where it stopped reporting and then I
> reconnected it (That's what the reboots are in the logs: when I
> reconnected the system after firmware installation and when I
> reconnected to reboot it)
> Given that it completely died for the best part of my trip, I'm
> tempted to suggest that it was a firmware bug.
> In addition, my Twizy now reports a range in the hundreds of miles!
> Congratulations, you broke the laws of physics (Or we've shifted to
> the right one too many!)
> Nikki.
> On 8 Apr 2013, at 16:14, Nikki Gordon-Bloomfield
> <nikki at littlecollie.com <mailto:nikki at littlecollie.com>> wrote:
>> Ok! I'll check when I get home!
>> Sent from my iPhone
>> On 8 Apr 2013, at 16:09, Michael Balzer <dexter at expeedo.de
>>> ...or an antenna / GSM problem, logs are sent on GSM connect also.
>>> Am 08.04.2013 17:02, schrieb Michael Balzer:
>>>> Nikki,
>>>> that rather looks like some problem with your OBD2 connector (12V
>>>> power supply), as the logs show only first boots instead of
>>>> resets/crashes.
>>>> Can you check that?
>>>> I have no problem running the last version I sent.
>>>> Thanks,
>>>> Michael
>>>> Am 08.04.2013 16:32, schrieb Nikki Gordon-Bloomfield:
>>>>> Michael,
>>>>> Here's my debug log. Any use?
>>>>> Nikki.
>>>>> OvmsDev mailing list
>>> <dexter.vcf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130408/eddb5825/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130408/eddb5825/attachment-0002.vcf>
