[Ovmsdev] i-Miev/C-Zero/iOn
Nikki Gordon-Bloomfield
nikki at littlecollie.com
Mon Apr 29 14:26:58 HKT 2013
HI Matt, Thomas,
I'd suggest at least one of you will need some form of CAN logger. Either a purpose-built device, or something that you can connect to a serial or USB port to pull date from your car?
See the roadster logs in GitHub ;)
I'd also recommend your read the development doc here: https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/OVMS_Development.pdf :)
Nikki.
On 29 Apr 2013, at 07:22, Matt Beard <matt at beard.tv> wrote:
> Hi, I have a C-Zero and would like OVMS support. I am currently considering buying a unit and would be able to help with development if/when I get one.
> Matt Beard
> On Monday, April 29, 2013, Thomas Bergo wrote:
> Hi
> As a owner of a i-Miev I'm interested in OVMS support for the i-Miev/C-Zero/iOn EV.
> Has anyone looked into supporting those EV?
> I'm planing to start looking into adding support for those EV. And asking for help to add a vehicle plug-in module stub for those cars, so that naming and so on is correct.
> Best regards
> Thomas B
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130429/9781cf2c/attachment.html>
