[Ovmsdev] 1.3.1
William Petefish william.petefish at gmail.com
Tue Sep 4 10:23:20 HKT 2012
Thanks for the clarification.
William
On Sep 3, 2012 9:22 PM, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
> William,
> It isn't supposed to notify you when a charge completes normally, only
> when it is interrupted.
> For example:
>    - SOC at 90%, plug it in and let charge complete normally -> No
>    notification
>    - SOC at 90%, plug it in, but when SOC reaches 92% unplug to interrupt
>    the charge -> Notification will be raised
> Is that what you mean?
> On 4 Sep, 2012, at 10:17 AM, William Petefish wrote:
> Unplugging works, but it doesn't notify you when a charge is completed.
> Only after unplugging does it send any messages.
> William
> On Sep 3, 2012 7:46 PM, "William Petefish" <william.petefish at gmail.com>
> wrote:
>> SMS and IP are selected. I'll try unplugging while charging tonight.
>> William
>> On Sep 3, 2012 7:03 PM, "Mark Webb-Johnson" <mark at webb-johnson.net>
>> wrote:
>>> William,
>>> I suggest you check the 'features' and 'parameters' set on the phone.
>>> Make sure notifications are enabled. In particular, the notification method
>>> should be "SMSIP" (or SMS or IP alone).
>>> To test a charge alert, plug the car in and start a charge. Make sure
>>> the App is showing the charge in progress (it takes about a minute for the
>>> car to start the charge). Then, on the car itself, slide the plug switch to
>>> off (or interrupt by circuit breaker if you want to be more abrupt). That
>>> will interrupt the charge, and generate a 'stopped' charge state 100% of
>>> the time. You should then get a notification however you've configured it.
>>> Stopping the charge from the cellphone apps or sms messages should not
>>> generate an alert. If the charge completes normally, it will end in 'done'
>>> state and that should also not generate an alert.
>>> If someone cars to try, the extension cord detected error message in the
>>> car should now result in charge stopped notifications. You won't get the
>>> detailed reason message, but you should get the alert.
>>> On 4 Sep, 2012, at 3:42 AM, William Petefish wrote:
>>> As of late, I haven't been getting the charge finished notifications.
>>> The app says that the charge is complete, but OVMS waits for me to unplug
>>> the car before it sends any notifications. (those stopped sometime within
>>> the last two weeks.)
>>> BTW this is a Roadster 2.5 non-sport.
>>> William
>>> On Mon, Sep 3, 2012 at 12:03 AM, Mark Webb-Johnson <
>>>> Thanks William, I see 5 now.
>>>> Most helpful thing people on this list can do to help out this week is
>>>> deploy this firmware to their car and help test it for stability. I am most
>>>> interested in:
>>>>    1. If the car is in an area of poor / no cellular coverage, then
>>>>    drives out to an area of good coverage, does OVMS connection re-establish?
>>>>    In particular, if you previously saw a situation where you had to
>>>>    unplug-then-plugin the module to hard-reset it, does that still happen? If
>>>>    realise that this will take longer to know, as it was very rare.
>>>>    2. If you interrupt charges in various ways, do you get SMS/PUSH
>>>>    notifications if the charge stopping?
>>>>    3. If charges complete normally, in various ways, do you get false
>>>>    SMS/PUSH notifications?
>>>>    4. Any weird numbers, or other problems, with Motor Temperature -
>>>>    particularly in very hot or very cold areas?
>>>>    5. Any weird numbers, or other problems, with ideal/estimated
>>>>    ranges - particularly when the battery is very full, very empty or when
>>>>    changing between standard and range modes?
>>>> Thanks, Mark.
>>>> On 3 Sep, 2012, at 11:29 AM, William Petefish wrote:
>>>> I'll be updating mine in a few min...
>>>> William
>>>> On Sun, Sep 2, 2012 at 8:36 PM, Mark Webb-Johnson <
>>>>> Tom,
>>>>> Thanks. Looks good. 4 cars updated to v1.3.1 overnight and all seem to
>>>>> be reporting in ok.
>>>>> I should have the production V2 modules in my hands today or tomorrow,
>>>>> and will send pictures of them with the pickit plugged in. I only have a
>>>>> pickit3, but it looks similar enough.
>>>>> To avoid confusion between V1 and V2, probably best to just include a
>>>>> picture of the two modules. They look so completely different, that should
>>>>> avoid any mistakes. We really don't want people to be flashing the wrong
>>>>> firmware to the wrong modules. In particular, for V2 devices, they will
>>>>> accept V1 firmware but a few things won't work properly (like the GSM/GPRS
>>>>> switch). I've been trying to work out how to pickup the processor ID so I
>>>>> can check at startup and refuse to run if the wrong firmware is flashed,
>>>>> but still not solved.
>>>>> Regards, Mark
>>>>> On 3 Sep, 2012, at 12:25 AM, Tom Saxton wrote:
>>>>> > I've updated my OVMS Firmware Update Guide.
>>>>> >    http://www.idleloop.com/tesla/ovms/
>>>>> > I need a photo of the PICkit2 programmer plugged into the V2 board
>>>>> correctly
>>>>> > to add to the page. Also, I'd like to know what device string
>>>>> appears in the
>>>>> > PICkit2 programmer software when connected to a V2 board.
>>>>> > I'll wait until it's officially released to post my install page
>>>>> update onto
>>>>> > TMC, or Mark you can just link to it when you post the release.
>>>>> >    Tom
>>>>> > on 9/1/12 11:45 PM, Mark Webb-Johnson wrote:
>>>>> >> Car firmware 1.3.1 is in GitHub now. I built all variants to .hex
>>>>> files, and
>>>>> >> source is there for the adventurous. Tom: can you help setup
>>>>> end-user
>>>>> >> instructions of this?
>>>>> >> All outstanding car issues recorded on github have been resolved
>>>>> and closed
>>>>> >> with this version.
>>>>> >> It has been running in my car for a few days, and seems fine. I did
>>>>> a few
>>>>> >> different charge-interruption tests, and they all alert as expected.
>>>>> >> I'm gonna wait a few days to allow you guys some time to try it out
>>>>> and report
>>>>> >> any issues (hopefully none). I'll then announce it as generally
>>>>> available. Due
>>>>> >> to the enhanced modem control, linear connection backup algorithm,
>>>>> bug fixes,
>>>>> >> and new improved notification algorithm, this will be a recommended
>>>>> update for
>>>>> >> all users.
>>>>> >> Regards, Mark
>>>>> >> _______________________________________________
>>>>> >> OvmsDev mailing list
>>>>> >> OvmsDev at lists.teslaclub.hk
>>>>> >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120903/b63efd04/attachment.htm>
