[Ovmsdev] 1.3.1
William Petefish william.petefish at gmail.com
Tue Sep 4 08:46:03 HKT 2012
SMS and IP are selected. I'll try unplugging while charging tonight.
William
On Sep 3, 2012 7:03 PM, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
> William,
> I suggest you check the 'features' and 'parameters' set on the phone. Make
> sure notifications are enabled. In particular, the notification method
> should be "SMSIP" (or SMS or IP alone).
> To test a charge alert, plug the car in and start a charge. Make sure the
> App is showing the charge in progress (it takes about a minute for the car
> to start the charge). Then, on the car itself, slide the plug switch to off
> (or interrupt by circuit breaker if you want to be more abrupt). That will
> interrupt the charge, and generate a 'stopped' charge state 100% of the
> time. You should then get a notification however you've configured it.
> Stopping the charge from the cellphone apps or sms messages should not
> generate an alert. If the charge completes normally, it will end in 'done'
> state and that should also not generate an alert.
> If someone cars to try, the extension cord detected error message in the
> car should now result in charge stopped notifications. You won't get the
> detailed reason message, but you should get the alert.
> On 4 Sep, 2012, at 3:42 AM, William Petefish wrote:
> As of late, I haven't been getting the charge finished notifications. The
> app says that the charge is complete, but OVMS waits for me to unplug the
> car before it sends any notifications. (those stopped sometime within the
> last two weeks.)
> BTW this is a Roadster 2.5 non-sport.
> William
> On Mon, Sep 3, 2012 at 12:03 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
>> Thanks William, I see 5 now.
>> Most helpful thing people on this list can do to help out this week is
>> deploy this firmware to their car and help test it for stability. I am most
>> interested in:
>>    1. If the car is in an area of poor / no cellular coverage, then
>>    drives out to an area of good coverage, does OVMS connection re-establish?
>>    In particular, if you previously saw a situation where you had to
>>    unplug-then-plugin the module to hard-reset it, does that still happen? If
>>    realise that this will take longer to know, as it was very rare.
>>    2. If you interrupt charges in various ways, do you get SMS/PUSH
>>    notifications if the charge stopping?
>>    3. If charges complete normally, in various ways, do you get false
>>    SMS/PUSH notifications?
>>    4. Any weird numbers, or other problems, with Motor Temperature -
>>    particularly in very hot or very cold areas?
>>    5. Any weird numbers, or other problems, with ideal/estimated ranges
>>    - particularly when the battery is very full, very empty or when changing
>>    between standard and range modes?
>> Thanks, Mark.
>> On 3 Sep, 2012, at 11:29 AM, William Petefish wrote:
>> I'll be updating mine in a few min...
>> William
>> On Sun, Sep 2, 2012 at 8:36 PM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
>>> Tom,
>>> Thanks. Looks good. 4 cars updated to v1.3.1 overnight and all seem to
>>> be reporting in ok.
>>> I should have the production V2 modules in my hands today or tomorrow,
>>> and will send pictures of them with the pickit plugged in. I only have a
>>> pickit3, but it looks similar enough.
>>> To avoid confusion between V1 and V2, probably best to just include a
>>> picture of the two modules. They look so completely different, that should
>>> avoid any mistakes. We really don't want people to be flashing the wrong
>>> firmware to the wrong modules. In particular, for V2 devices, they will
>>> accept V1 firmware but a few things won't work properly (like the GSM/GPRS
>>> switch). I've been trying to work out how to pickup the processor ID so I
>>> can check at startup and refuse to run if the wrong firmware is flashed,
>>> but still not solved.
>>> Regards, Mark
>>> On 3 Sep, 2012, at 12:25 AM, Tom Saxton wrote:
>>> > I've updated my OVMS Firmware Update Guide.
>>> >    http://www.idleloop.com/tesla/ovms/
>>> > I need a photo of the PICkit2 programmer plugged into the V2 board
>>> correctly
>>> > to add to the page. Also, I'd like to know what device string appears
>>> in the
>>> > PICkit2 programmer software when connected to a V2 board.
>>> > I'll wait until it's officially released to post my install page
>>> update onto
>>> > TMC, or Mark you can just link to it when you post the release.
>>> >    Tom
>>> > on 9/1/12 11:45 PM, Mark Webb-Johnson wrote:
>>> >> Car firmware 1.3.1 is in GitHub now. I built all variants to .hex
>>> files, and
>>> >> source is there for the adventurous. Tom: can you help setup end-user
>>> >> instructions of this?
>>> >> All outstanding car issues recorded on github have been resolved and
>>> closed
>>> >> with this version.
>>> >> It has been running in my car for a few days, and seems fine. I did a
>>> few
>>> >> different charge-interruption tests, and they all alert as expected.
>>> >> I'm gonna wait a few days to allow you guys some time to try it out
>>> and report
>>> >> any issues (hopefully none). I'll then announce it as generally
>>> available. Due
>>> >> to the enhanced modem control, linear connection backup algorithm,
>>> bug fixes,
>>> >> and new improved notification algorithm, this will be a recommended
>>> update for
>>> >> all users.
>>> >> Regards, Mark
>>> >> _______________________________________________
>>> >> OvmsDev mailing list
>>> >> OvmsDev at lists.teslaclub.hk
>>> >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120903/d51ae8e3/attachment.htm>
