[Ovmsdev] 1.3.1
William Petefish william.petefish at gmail.com
Mon Sep 3 11:29:49 HKT 2012
I'll be updating mine in a few min...
William
On Sun, Sep 2, 2012 at 8:36 PM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
> Tom,
> Thanks. Looks good. 4 cars updated to v1.3.1 overnight and all seem to be
> reporting in ok.
> I should have the production V2 modules in my hands today or tomorrow, and
> will send pictures of them with the pickit plugged in. I only have a
> pickit3, but it looks similar enough.
> To avoid confusion between V1 and V2, probably best to just include a
> picture of the two modules. They look so completely different, that should
> avoid any mistakes. We really don't want people to be flashing the wrong
> firmware to the wrong modules. In particular, for V2 devices, they will
> accept V1 firmware but a few things won't work properly (like the GSM/GPRS
> switch). I've been trying to work out how to pickup the processor ID so I
> can check at startup and refuse to run if the wrong firmware is flashed,
> but still not solved.
> Regards, Mark
> On 3 Sep, 2012, at 12:25 AM, Tom Saxton wrote:
> > I've updated my OVMS Firmware Update Guide.
> >    http://www.idleloop.com/tesla/ovms/
> > I need a photo of the PICkit2 programmer plugged into the V2 board
> correctly
> > to add to the page. Also, I'd like to know what device string appears in
> the
> > PICkit2 programmer software when connected to a V2 board.
> > I'll wait until it's officially released to post my install page update
> onto
> > TMC, or Mark you can just link to it when you post the release.
> >    Tom
> > on 9/1/12 11:45 PM, Mark Webb-Johnson wrote:
> >> Car firmware 1.3.1 is in GitHub now. I built all variants to .hex
> files, and
> >> source is there for the adventurous. Tom: can you help setup end-user
> >> instructions of this?
> >> All outstanding car issues recorded on github have been resolved and
> closed
> >> with this version.
> >> It has been running in my car for a few days, and seems fine. I did a
> few
> >> different charge-interruption tests, and they all alert as expected.
> >> I'm gonna wait a few days to allow you guys some time to try it out and
> report
> >> any issues (hopefully none). I'll then announce it as generally
> available. Due
> >> to the enhanced modem control, linear connection backup algorithm, bug
> fixes,
> >> and new improved notification algorithm, this will be a recommended
> update for
> >> all users.
> >> Regards, Mark
> >> _______________________________________________
> >> OvmsDev mailing list
> >> OvmsDev at lists.teslaclub.hk
> >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120902/c8df3c7b/attachment.htm>
