[Ovmsdev] New features: sufficient charge alerts, ideal max range
Wed Nov 14 01:41:54 HKT 2012
Mark,
I'm sure it was a full reset, and they still occur frequently, but only
while charging it seems.
I just checked RCON and STKPTR: it seems the resets are due to watchdog
timeouts (TO).
Do I need to instrument the code with some checkpoints (storing
checkpoint ids into a persistent feature) to track down where this
occurs, or is there an easier way?
Do you have a suggestion where to go hunting first? It's most probably
not in my Twizy code, as I've got no loop condition at all.
Thanks,
PS: here's the RCON checking code for others trying to debug similar
problems:
Insert this right at the top of main() just after clearing sys_features[]:
// DEBUG: save last reset reason in feature 7 (RCON bits inverted for
readability):
sys_features[7] = (~RCON) & 0x1f;
if( STKPTRbits.STKFUL ) sys_features[7] += 32;
if( STKPTRbits.STKUNF ) sys_features[7] += 64;
// ...and clear RCON:
RCONbits.NOT_BOR = 1; // b0 = 1 = Brown Out Reset
RCONbits.NOT_POR = 1; // b1 = 2 = Power On Reset
//RCONbits.NOT_PD = 1; // b2 = 4 = Power Down detection
//RCONbits.NOT_TO = 1; // b3 = 8 = watchdog TimeOut occured
RCONbits.NOT_RI = 1; // b4 = 16 = Reset Instruction
=> a feature dump will show the last reset reason.
Am 12.11.2012 01:07, schrieb Mark Webb-Johnson:
> Michael,
> The feature #10 was somewhere we suspected was a problem, so added the
> record there. But, I too have never seen it fire. I was planning on
> removing the check for the next firmware.
> The modem resetting, in GSM/GPRS outages, is normal and expected. But,
> the module should not reset under normal conditions. If you are seeing
> this, then it is either a code fault (an endless loop, most likely) or
> stack overflow, causing watchdog timer to fire.
> When you say you saw the module reset, are you sure it wasn't a modem
> reset? If the module resets you'll get the firmware version being
> blinked out. Modem resets are highlighted by both red and green leds
> being constant on for a second or two.
> On 12 Nov, 2012, at 12:56 AM, Michael Balzer wrote:
>> Mark,
>> it doesn't seem the old Android App supports setting arbitrary
>> features? I currently have to use SMS to set them.
>> I need these configs to be persistent as the module does quite a lot
>> of resets at the moment, it seems especially if GPRS connectivity is bad.
>> I just had to take yet another persistent feature slot (13) in use to
>> store my last known range due to permanently losing my range
>> calculations during charge.
>> I tried to sort out why I get those resets and found the
>> // Temporary kludge to record in feature #10 the number of times
>> this happened
>> ...but my value was not increased, even after I watched the module
>> doing a reset.
>> Is there another condition for an automatic reset? I found none...
>> I thought feature slots are especially meant for this kind of user
>> configuration. I could avoid using feature slots at all if a) the
>> module would only do a reset if absolutely needed (so I don't lose my
>> local configuration) and b) I can introduce a car specific command to
>> set my local configuration. Or is there another way?
>> Am 11.11.2012 13:35, schrieb Mark Webb-Johnson:
>>> Michael,
>>> I guess you need these as features, so they can be set from the App?
>>> If so, can they be put as experimental at the moment? Those won't
>>> survive a reboot, but are less impacting. I suggest 0x05, 0x06 and 0x07.
>>> For MAXRANGE, that is fine. Make it a permanent feature, 0x0D.
>>> On 11 Nov, 2012, at 7:42 AM, Michael Balzer <dexter at expeedo.de
>>> <mailto:dexter at expeedo.de>> wrote:
>>>> Mark,
>>>> I just checked in my latest Twizy updates:
>>>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/0a70e483baf182f4226d1a1afc8d0734c2fa48d9
>>>> These contain two extensions that could be generally useful:
>>>> 1) As the Twizy "ideal" range varies widely depending on your
>>>> driving, geography and environment, I implemented a feature for
>>>> that config.
>>>> 2) If I just need an intermediate charge for a certain SOC or range
>>>> (to get home for example), I can now activate an alert for one or
>>>> both values.
>>>> I used the next three free feature slots for these:
>>>> #define FEATURE_SUFFSOC 0x0A // Sufficient SOC feature
>>>> #define FEATURE_SUFFRANGE 0x0B // Sufficient range feature
>>>> #define FEATURE_MAXRANGE 0x0C // Maximum ideal range feature
>>>> I know, feature slots are getting full... what do you think?
>>>> Regards,
>>>> Michael
>>>> <dexter.vcf>_______________________________________________
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121113/e919e0bf/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121113/e919e0bf/attachment-0002.vcf>
