[Ovmsdev] New features: sufficient charge alerts, ideal max range
Mon Nov 12 08:07:06 HKT 2012
Michael,
The feature #10 was somewhere we suspected was a problem, so added the record there. But, I too have never seen it fire. I was planning on removing the check for the next firmware.
The modem resetting, in GSM/GPRS outages, is normal and expected. But, the module should not reset under normal conditions. If you are seeing this, then it is either a code fault (an endless loop, most likely) or stack overflow, causing watchdog timer to fire.
When you say you saw the module reset, are you sure it wasn't a modem reset? If the module resets you'll get the firmware version being blinked out. Modem resets are highlighted by both red and green leds being constant on for a second or two.
On 12 Nov, 2012, at 12:56 AM, Michael Balzer wrote:
> Mark,
> it doesn't seem the old Android App supports setting arbitrary features? I currently have to use SMS to set them.
> I need these configs to be persistent as the module does quite a lot of resets at the moment, it seems especially if GPRS connectivity is bad.
> I just had to take yet another persistent feature slot (13) in use to store my last known range due to permanently losing my range calculations during charge.
> I tried to sort out why I get those resets and found the
>    // Temporary kludge to record in feature #10 the number of times this happened
> ...but my value was not increased, even after I watched the module doing a reset.
> Is there another condition for an automatic reset? I found none...
> I thought feature slots are especially meant for this kind of user configuration. I could avoid using feature slots at all if a) the module would only do a reset if absolutely needed (so I don't lose my local configuration) and b) I can introduce a car specific command to set my local configuration. Or is there another way?
> Am 11.11.2012 13:35, schrieb Mark Webb-Johnson:
>> Michael,
>> I guess you need these as features, so they can be set from the App?
>> If so, can they be put as experimental at the moment? Those won't survive a reboot, but are less impacting. I suggest 0x05, 0x06 and 0x07.
>> For MAXRANGE, that is fine. Make it a permanent feature, 0x0D.
>> On 11 Nov, 2012, at 7:42 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Mark,
>>> I just checked in my latest Twizy updates:
>>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/0a70e483baf182f4226d1a1afc8d0734c2fa48d9
>>> These contain two extensions that could be generally useful:
>>> 1) As the Twizy "ideal" range varies widely depending on your driving, geography and environment, I implemented a feature for that config.
>>> 2) If I just need an intermediate charge for a certain SOC or range (to get home for example), I can now activate an alert for one or both values.
>>> I used the next three free feature slots for these:
>>> #define FEATURE_SUFFSOC      0x0A // Sufficient SOC feature
>>> #define FEATURE_SUFFRANGE    0x0B // Sufficient range feature
>>> #define FEATURE_MAXRANGE     0x0C // Maximum ideal range feature
>>> I know, feature slots are getting full... what do you think?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121112/282178ae/attachment.htm>
