[Ovmsdev] Car firmware: 1.2.5
William Petefish william.petefish at gmail.com
Tue May 15 11:57:46 HKT 2012
I had trouble with logging. I'll try again in a few days.
William
On May 13, 2012 1:11 AM, "William Petefish" <william.petefish at gmail.com>
wrote:
> I'll do a logging session on monday.
> I've actually got 2 tools that I can use. (logic analyzer w/ data logging
> and analyzation functionality, and my CAN-USB which has CAN Hacker which
> can log and can give individual messages.)
> William
> On Sun, May 13, 2012 at 12:14 AM, Mark Webb-Johnson <mark at webb-johnson.net
> > wrote:
>> William,
>> If you get a chance, just get a full log dump of that can bus the OVMS
>> uses. Textual is fine (csv, whatever) and a timestamp would be useful. I'm
>> willing to do the analysis, I just need a can dump containing home link
>> transmission messages.
>> Useful if you can key the home link to some other recognizable event. For
>> example, open passenger door, activate home link, close passenger door. We
>> then need only to look at a short part of the log, looking for something
>> new. Car doors are good, but also trunk and hood. Keep clear of charge port
>> because opening that triggers all sorts of other stuff. Also good if you
>> can do it a few times. Whichever, let us know the exact sequence (eg; open
>> left door @15sec in, activate home link 1 about 2 seconds later, then
>> closed left door, did this three times, etc) and how you keyed the event.
>> If you want to look for the event itself, all we know is at:
>> https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/master/vehicle/Car%20Module/canbus_notes.txt
>> A sub-message <B1> on ID#102 is the most likely, as those are messages
>> from the VDS.
>> Regards, Mark
>> On 13 May, 2012, at 12:37 PM, William Petefish <
>> william.petefish at gmail.com> wrote:
>> I have CAN Hacker on my netbook. I also have a USB-CAN interface. I don't
>> know how much time I'll have in the next week or so. All bets are off, but
>> I'll try to get some work done next week.
>> William
>> On Sat, May 12, 2012 at 9:24 PM, Mark Webb-Johnson <mark at webb-johnson.net
>> > wrote:
>>> To track down the homelink messages, we'd need someone with both
>>> homelink and a way to capture can bus messages (a USB CAN bus tool).
>>> I have the tool, but the cars in hong kong have no homelink module
>>> installed.
>>> The capture itself should be fairly simple. I'd put money on the
>>> messages being on ID#102, and there are a very limited number of those
>>> messages.
>>> On 13 May, 2012, at 12:25 AM, 911carrera4 wrote:
>>> Hallo everybody****
>>> I was able to configurate the HomeLinks on both our EU-Roadsters (my
>>> wife‘s and mine). We have two garages with two doors. For the opening of
>>> the doors we use a german product called  maraton 1100SL (the company is
>>> Sommer, D- 73230 Kirheim)****
>>> I did it in two steps:****
>>> 1.       I sent the code from the garage remote control to the Roadster
>>> (as described in the Tesla manual „How to configurate HomeLink“)****
>>> 2.       I paired (linked) the HomeLink from the Roadster to the
>>> control panel of the garage door (as described in the manual you get with
>>> your garage door control pannel)****
>>> That‘s all. It works good, but the range is  a bit shorter than with the
>>> original remote control.****
>>> The frequency of the System is 868Mhz (without external antenna).****
>>> Piotr****
>>>  *Von:* ovmsdev-bounces at lists.teslaclub.hk [mailto:
>>> ovmsdev-bounces at lists.teslaclub.hk] *Im Auftrag von *David Morse
>>> *Gesendet:* Samstag, 12. Mai 2012 17:22
>>> *An:* OVMS Developers
>>> *Betreff:* Re: [Ovmsdev] Car firmware: 1.2.5****
>>> Thank you all for working on this. I'm just an end user so can't
>>> contribute much more than comments but am looking forward to the cool down
>>> feature. I am curious though, does anyone have evidence that the cool down
>>> feature in beneficial?  If so, I wonder why this is something Tesla never
>>> implemented. Thanks. ****
>>> David
>>> Sent from my iPad****
>>> On May 12, 2012, at 9:33 AM, "Oliver Weidmann" <oliver at sdds.ch> wrote:**
>>> A guy from Switzerland has a working homelink. I’ll have to ask him how
>>> he managed to successfully pair it…****
>>> [mailto:ovmsdev-bounces at lists.teslaclub.hk] *Im Auftrag von*Pierre Uhl
>>> *Gesendet:* Samstag, 12. Mai 2012 13:39
>>> *An:* 'OVMS Developers'
>>> Re Homelink****
>>> The Homelink in Europe is disabled, because the frequency in Europe is
>>> not the same like in the US (FCC regulation?).****
>>> [mailto:ovmsdev-bounces at lists.teslaclub.hk] *Im Auftrag von*Mark
>>> Webb-Johnson
>>> *Gesendet:* Samstag, 12. Mai 2012 13:22
>>> *Betreff:* [Ovmsdev] Car firmware: 1.2.5****
>>> I've committed to github car firmware v1.2.5.****
>>> Changes since v1.2.2 include:****
>>>    - Support multiple vehicle configurations - TeslaRoadster and
>>>    VoltAmpera****
>>>    - New LED indication scheme, and net driver tidy-ups****
>>>    - Auto-support Tesla Roadster v1.5 cars****
>>>    - Issue #38 - Prevent user from locking car if car is ON****
>>>    - Issue #39 - Alert (SMS/PUSH) if trunk is opened while in valet mode
>>> Please don't get too excited - this doesn't support Volt/Ampera yet -
>>> we're just laying the ground work for that support, as some European
>>> developers are about to start work on it.****
>>> I don't think this release will make it to end-users in its current
>>> form. I'm still working on some features to go in, including:****
>>>    1. Drive logging****
>>>    2. Charge logging****
>>>    3. Timed (delayed) charging mode commands****
>>>    4. Timed charging status feedback****
>>>    5. Complete-charging-by charging mode****
>>>    6. Cooldown****
>>>    7. Moving digital speedo out of experimental and make it available
>>>    in production units****
>>> Items [1], [2] and [3] are relatively easy and what I'm working on now.*
>>> Item [4] is tricky because we haven't found the status update message on
>>> the bus yet. Still looking. Item [5] needs the algorithm and lookup table.
>>> Item [6] is easy to do, but needs the thresholds defined (what battery
>>> temperature to cooldown from, what battery temperature to stop cooldown at,
>>> and what current/voltage to use for cooldown).****
>>> Item [7] seems reasonable now, given the number of cars now using the
>>> digital speedo feature and the complete lack of issues seen with it.****
>>> I notice there was some discussion on the TMC forum about homelink
>>> control. That would be pretty easy to do, but we don't have homelink
>>> modules here in Hong Kong, and I don't have the can bus codes. They are
>>> probably easy to find on ID#102. If someone with a usb-can and a homelink
>>> adaptor wants to get the codes, I'm very willing to put them in. It
>>> certainly is a cool feature.****
>>> So, I'm not sure what will make it into what release, when.****
>>> This v1.2.5 release is definitely developers-only, and intended to check
>>> stability of the modem driver revisions and usability of the new LED
>>> feedback scheme. It is fully backwards-compatible with v1.2.2, and you can
>>> upgrade/downgrade firmware as you need.****
>>> It is in my car now, and seems to be ok. I would be grateful if
>>> developers with some time could try it out and let me have feedback on
>>> overall stability and usability of the new LED indication scheme.****
>>> I've got a little youtube video demonstrating this:****
>>> http://www.youtube.com/watch?v=MdsB8qK6beY****
>>> The new LED indication scheme is as follows:****
>>>    1. When first powered on, the red led stays on, and the green led
>>>    blinks the version of firmware in the module (e.g.; 1, 2, 5). After that,
>>>    it enters normal mode.****
>>>    2. In normal mode, the green led is used to indicate the state, and
>>>    the red led is used to indicate the last error.****
>>>    3. If the modem needs to be reset, both red and green leds are
>>>    turned on for the couple of seconds it takes to reset the modem.****
>>> The following states are defined:****
>>> // LED MODES
>>> #define NET_LED_WAKEUP       10    // Attempting to wake up the modem
>>> #define NET_LED_INITSIM1     9     // Checking SIM card insertion status
>>> #define NET_LED_INITSIM2     8     // Checking SIM card PIN status
>>> #define NET_LED_INITSIM3     7     // Initialising modem
>>> #define NET_LED_COPS         6     // COPS initialisation
>>> #define NET_LED_NETINIT      5     // GPRS NET initialisation
>>> #define NET_LED_NETAPNOK     4     // GPRS APN is OK, final init
>>> #define NET_LED_NETCALL      3     // GPRS Network call
>>> #define NET_LED_READY        2     // READY state
>>> #define NET_LED_READYGPRS    1     // READY GPRS state****
>>> The normal behavior is it will start at 10 green blinks and count down
>>> to 2 (GSM only) or 1 (GPRS). If GPRS lock is lost, but GSM is still up, the
>>> green will blink 1.****
>>> The followed error codes are defined:****
>>> // LED ERRORS
>>> #define NET_LED_ERRLOSTSIG   1     // Lost signal
>>> #define NET_LED_ERRMODEM     2     // Problem communicating with modem
>>> #define NET_LED_ERRSIM1      3     // SIM is not inserted/detected
>>> #define NET_LED_ERRSIM2      4     // PIN lock on the SIM
>>> #define NET_LED_ERRCOPS      6     // COPS GSM lock could not be obtained
>>> #define NET_LED_ERRGPRSRETRY 7     // Error (maybe temp) during GPRS init
>>> #define NET_LED_ERRGPRSFAIL  8     // GPRS NET INIT failed****
>>> The error code is cleared (red led turned off) once everything is ok.***
>>> Regards, Mark.****
>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev****
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120514/4dbdcaa2/attachment.htm>
