[Ovmsdev] Car firmware: 1.2.5
William Petefish william.petefish at gmail.com
Sun May 13 14:11:06 HKT 2012
I'll do a logging session on monday.
I've actually got 2 tools that I can use. (logic analyzer w/ data logging
and analyzation functionality, and my CAN-USB which has CAN Hacker which
can log and can give individual messages.)
William
On Sun, May 13, 2012 at 12:14 AM, Mark Webb-Johnson
<mark at webb-johnson.net>wrote:
> William,
> If you get a chance, just get a full log dump of that can bus the OVMS
> uses. Textual is fine (csv, whatever) and a timestamp would be useful. I'm
> willing to do the analysis, I just need a can dump containing home link
> transmission messages.
> Useful if you can key the home link to some other recognizable event. For
> example, open passenger door, activate home link, close passenger door. We
> then need only to look at a short part of the log, looking for something
> new. Car doors are good, but also trunk and hood. Keep clear of charge port
> because opening that triggers all sorts of other stuff. Also good if you
> can do it a few times. Whichever, let us know the exact sequence (eg; open
> left door @15sec in, activate home link 1 about 2 seconds later, then
> closed left door, did this three times, etc) and how you keyed the event.
> If you want to look for the event itself, all we know is at:
> https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/master/vehicle/Car%20Module/canbus_notes.txt
> A sub-message <B1> on ID#102 is the most likely, as those are messages
> from the VDS.
> Regards, Mark
> On 13 May, 2012, at 12:37 PM, William Petefish <william.petefish at gmail.com>
> wrote:
> I have CAN Hacker on my netbook. I also have a USB-CAN interface. I don't
> know how much time I'll have in the next week or so. All bets are off, but
> I'll try to get some work done next week.
> William
> On Sat, May 12, 2012 at 9:24 PM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
>> To track down the homelink messages, we'd need someone with both homelink
>> and a way to capture can bus messages (a USB CAN bus tool).
>> I have the tool, but the cars in hong kong have no homelink module
>> installed.
>> The capture itself should be fairly simple. I'd put money on the messages
>> being on ID#102, and there are a very limited number of those messages.
>> On 13 May, 2012, at 12:25 AM, 911carrera4 wrote:
>> Hallo everybody****
>> I was able to configurate the HomeLinks on both our EU-Roadsters (my
>> wife‘s and mine). We have two garages with two doors. For the opening of
>> the doors we use a german product called  maraton 1100SL (the company is
>> Sommer, D- 73230 Kirheim)****
>> I did it in two steps:****
>> 1.       I sent the code from the garage remote control to the Roadster
>> (as described in the Tesla manual „How to configurate HomeLink“)****
>> 2.       I paired (linked) the HomeLink from the Roadster to the control
>> panel of the garage door (as described in the manual you get with your
>> garage door control pannel)****
>> That‘s all. It works good, but the range is  a bit shorter than with the
>> original remote control.****
>> The frequency of the System is 868Mhz (without external antenna).****
>> Piotr****
>>  *Von:* ovmsdev-bounces at lists.teslaclub.hk [mailto:
>> ovmsdev-bounces at lists.teslaclub.hk] *Im Auftrag von *David Morse
>> *Gesendet:* Samstag, 12. Mai 2012 17:22
>> *An:* OVMS Developers
>> *Betreff:* Re: [Ovmsdev] Car firmware: 1.2.5****
>> Thank you all for working on this. I'm just an end user so can't
>> contribute much more than comments but am looking forward to the cool down
>> feature. I am curious though, does anyone have evidence that the cool down
>> feature in beneficial?  If so, I wonder why this is something Tesla never
>> implemented. Thanks. ****
>> David
>> Sent from my iPad****
>> On May 12, 2012, at 9:33 AM, "Oliver Weidmann" <oliver at sdds.ch> wrote:***
>> A guy from Switzerland has a working homelink. I’ll have to ask him how
>> he managed to successfully pair it…****
>> [mailto:ovmsdev-bounces at lists.teslaclub.hk] *Im Auftrag von*Pierre Uhl
>> *Gesendet:* Samstag, 12. Mai 2012 13:39
>> *An:* 'OVMS Developers'
>> Re Homelink****
>> The Homelink in Europe is disabled, because the frequency in Europe is
>> not the same like in the US (FCC regulation?).****
>> [mailto:ovmsdev-bounces at lists.teslaclub.hk] *Im Auftrag von*Mark
>> Webb-Johnson
>> *Gesendet:* Samstag, 12. Mai 2012 13:22
>> *Betreff:* [Ovmsdev] Car firmware: 1.2.5****
>> I've committed to github car firmware v1.2.5.****
>> Changes since v1.2.2 include:****
>>    - Support multiple vehicle configurations - TeslaRoadster and
>>    VoltAmpera****
>>    - New LED indication scheme, and net driver tidy-ups****
>>    - Auto-support Tesla Roadster v1.5 cars****
>>    - Issue #38 - Prevent user from locking car if car is ON****
>>    - Issue #39 - Alert (SMS/PUSH) if trunk is opened while in valet mode*
>> Please don't get too excited - this doesn't support Volt/Ampera yet -
>> we're just laying the ground work for that support, as some European
>> developers are about to start work on it.****
>> I don't think this release will make it to end-users in its current form.
>> I'm still working on some features to go in, including:****
>>    1. Drive logging****
>>    2. Charge logging****
>>    3. Timed (delayed) charging mode commands****
>>    4. Timed charging status feedback****
>>    5. Complete-charging-by charging mode****
>>    6. Cooldown****
>>    7. Moving digital speedo out of experimental and make it available in
>>    production units****
>> Items [1], [2] and [3] are relatively easy and what I'm working on now.**
>> Item [4] is tricky because we haven't found the status update message on
>> the bus yet. Still looking. Item [5] needs the algorithm and lookup table.
>> Item [6] is easy to do, but needs the thresholds defined (what battery
>> temperature to cooldown from, what battery temperature to stop cooldown at,
>> and what current/voltage to use for cooldown).****
>> Item [7] seems reasonable now, given the number of cars now using the
>> digital speedo feature and the complete lack of issues seen with it.****
>> I notice there was some discussion on the TMC forum about homelink
>> control. That would be pretty easy to do, but we don't have homelink
>> modules here in Hong Kong, and I don't have the can bus codes. They are
>> probably easy to find on ID#102. If someone with a usb-can and a homelink
>> adaptor wants to get the codes, I'm very willing to put them in. It
>> certainly is a cool feature.****
>> So, I'm not sure what will make it into what release, when.****
>> This v1.2.5 release is definitely developers-only, and intended to check
>> stability of the modem driver revisions and usability of the new LED
>> feedback scheme. It is fully backwards-compatible with v1.2.2, and you can
>> upgrade/downgrade firmware as you need.****
>> It is in my car now, and seems to be ok. I would be grateful if
>> developers with some time could try it out and let me have feedback on
>> overall stability and usability of the new LED indication scheme.****
>> I've got a little youtube video demonstrating this:****
>> http://www.youtube.com/watch?v=MdsB8qK6beY****
>> The new LED indication scheme is as follows:****
>>    1. When first powered on, the red led stays on, and the green led
>>    blinks the version of firmware in the module (e.g.; 1, 2, 5). After that,
>>    it enters normal mode.****
>>    2. In normal mode, the green led is used to indicate the state, and
>>    the red led is used to indicate the last error.****
>>    3. If the modem needs to be reset, both red and green leds are turned
>>    on for the couple of seconds it takes to reset the modem.****
>> The following states are defined:****
>> // LED MODES
>> #define NET_LED_WAKEUP       10    // Attempting to wake up the modem
>> #define NET_LED_INITSIM1     9     // Checking SIM card insertion status
>> #define NET_LED_INITSIM2     8     // Checking SIM card PIN status
>> #define NET_LED_INITSIM3     7     // Initialising modem
>> #define NET_LED_COPS         6     // COPS initialisation
>> #define NET_LED_NETINIT      5     // GPRS NET initialisation
>> #define NET_LED_NETAPNOK     4     // GPRS APN is OK, final init
>> #define NET_LED_NETCALL      3     // GPRS Network call
>> #define NET_LED_READY        2     // READY state
>> #define NET_LED_READYGPRS    1     // READY GPRS state****
>> The normal behavior is it will start at 10 green blinks and count down to
>> 2 (GSM only) or 1 (GPRS). If GPRS lock is lost, but GSM is still up, the
>> green will blink 1.****
>> The followed error codes are defined:****
>> // LED ERRORS
>> #define NET_LED_ERRLOSTSIG   1     // Lost signal
>> #define NET_LED_ERRMODEM     2     // Problem communicating with modem
>> #define NET_LED_ERRSIM1      3     // SIM is not inserted/detected
>> #define NET_LED_ERRSIM2      4     // PIN lock on the SIM
>> #define NET_LED_ERRCOPS      6     // COPS GSM lock could not be obtained
>> #define NET_LED_ERRGPRSRETRY 7     // Error (maybe temp) during GPRS init
>> #define NET_LED_ERRGPRSFAIL  8     // GPRS NET INIT failed****
>> The error code is cleared (red led turned off) once everything is ok.****
>> Regards, Mark.****
>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev****
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120513/f3d8d759/attachment.htm>
