[Ovmsdev] Car firmware: 1.2.5
Michael Stegen
michael at stegen.com
Wed May 16 03:35:05 HKT 2012
I also have homelink on my car, and a garage door to test it on, so i'll
give it a try asap.
Op 13-5-2012 4:24, Mark Webb-Johnson schreef:
> To track down the homelink messages, we'd need someone with both
> homelink and a way to capture can bus messages (a USB CAN bus tool).
> I have the tool, but the cars in hong kong have no homelink module
> installed.
> The capture itself should be fairly simple. I'd put money on the
> messages being on ID#102, and there are a very limited number of those
> messages.
> On 13 May, 2012, at 12:25 AM, 911carrera4 wrote:
>> Hallo everybody
>> I was able to configurate the HomeLinks on both our EU-Roadsters (my
>> wife's and mine). We have two garages with two doors. For the opening
>> of the doors we use a german product called maraton 1100SL (the
>> company is Sommer, D- 73230 Kirheim)
>> I did it in two steps:
>> 1.I sent the code from the garage remote control to the Roadster (as
>> described in the Tesla manual "How to configurate HomeLink")
>> 2.I paired (linked) the HomeLink from the Roadster to the control
>> panel of the garage door (as described in the manual you get with
>> your garage door control pannel)
>> That's all. It works good, but the range is a bit shorter than with
>> the original remote control.
>> The frequency of the System is 868Mhz (without external antenna).
>> Piotr
>> *Von:*ovmsdev-bounces at lists.teslaclub.hk
>> <mailto:ovmsdev-bounces at lists.teslaclub.hk>[mailto:ovmsdev-bounces at lists.teslaclub.hk]*Im
>> Auftrag von*David Morse
>> *Gesendet:*Samstag, 12. Mai 2012 17:22
>> *An:*OVMS Developers
>> *Betreff:*Re: [Ovmsdev] Car firmware: 1.2.5
>> Thank you all for working on this. I'm just an end user so can't
>> contribute much more than comments but am looking forward to the cool
>> down feature. I am curious though, does anyone have evidence that the
>> cool down feature in beneficial? If so, I wonder why this is
>> something Tesla never implemented. Thanks.
>> David
>> Sent from my iPad
>> On May 12, 2012, at 9:33 AM, "Oliver Weidmann" <oliver at sdds.ch
>> <mailto:oliver at sdds.ch>> wrote:
>> A guy from Switzerland has a working homelink. I'll have to ask
>> him how he managed to successfully pair it...
>> <mailto:[mailto:ovmsdev-bounces at lists.teslaclub.hk]>*Im Auftrag
>> von*Pierre Uhl
>> *Gesendet:*Samstag, 12. Mai 2012 13:39
>> *An:*'OVMS Developers'
>> Re Homelink
>> The Homelink in Europe is disabled, because the frequency in
>> Europe is not the same like in the US (FCC regulation?).
>> von*Mark Webb-Johnson
>> *Gesendet:*Samstag, 12. Mai 2012 13:22
>> *Betreff:*[Ovmsdev] Car firmware: 1.2.5
>> I've committed to github car firmware v1.2.5.
>> Changes since v1.2.2 include:
>> * Support multiple vehicle configurations - TeslaRoadster and
>> VoltAmpera
>> * New LED indication scheme, and net driver tidy-ups
>> * Auto-support Tesla Roadster v1.5 cars
>> * Issue #38 - Prevent user from locking car if car is ON
>> * Issue #39 - Alert (SMS/PUSH) if trunk is opened while in
>> valet mode
>> Please don't get too excited - this doesn't support Volt/Ampera
>> yet - we're just laying the ground work for that support, as some
>> European developers are about to start work on it.
>> I don't think this release will make it to end-users in its
>> current form. I'm still working on some features to go in, including:
>> 1. Drive logging
>> 2. Charge logging
>> 3. Timed (delayed) charging mode commands
>> 4. Timed charging status feedback
>> 5. Complete-charging-by charging mode
>> 6. Cooldown
>> 7. Moving digital speedo out of experimental and make it
>> available in production units
>> Items [1], [2] and [3] are relatively easy and what I'm working
>> on now.
>> Item [4] is tricky because we haven't found the status update
>> message on the bus yet. Still looking. Item [5] needs the
>> algorithm and lookup table. Item [6] is easy to do, but needs the
>> thresholds defined (what battery temperature to cooldown from,
>> what battery temperature to stop cooldown at, and what
>> current/voltage to use for cooldown).
>> Item [7] seems reasonable now, given the number of cars now using
>> the digital speedo feature and the complete lack of issues seen
>> with it.
>> I notice there was some discussion on the TMC forum about
>> homelink control. That would be pretty easy to do, but we don't
>> have homelink modules here in Hong Kong, and I don't have the can
>> bus codes. They are probably easy to find on ID#102. If someone
>> with a usb-can and a homelink adaptor wants to get the codes, I'm
>> very willing to put them in. It certainly is a cool feature.
>> So, I'm not sure what will make it into what release, when.
>> This v1.2.5 release is definitely developers-only, and intended
>> to check stability of the modem driver revisions and usability of
>> the new LED feedback scheme. It is fully backwards-compatible
>> with v1.2.2, and you can upgrade/downgrade firmware as you need.
>> It is in my car now, and seems to be ok. I would be grateful if
>> developers with some time could try it out and let me have
>> feedback on overall stability and usability of the new LED
>> indication scheme.
>> I've got a little youtube video demonstrating this:
>> http://www.youtube.com/watch?v=MdsB8qK6beY
>> The new LED indication scheme is as follows:
>> 1. When first powered on, the red led stays on, and the green
>> led blinks the version of firmware in the module (e.g.; 1, 2,
>> 5). After that, it enters normal mode.
>> 2. In normal mode, the green led is used to indicate the state,
>> and the red led is used to indicate the last error.
>> 3. If the modem needs to be reset, both red and green leds are
>> turned on for the couple of seconds it takes to reset the modem.
>> The following states are defined:
>> // LED MODES
>> #define NET_LED_WAKEUP 10 // Attempting to wake up
>> the modem
>> #define NET_LED_INITSIM1 9 // Checking SIM card
>> insertion status
>> #define NET_LED_INITSIM2 8 // Checking SIM card PIN
>> status
>> #define NET_LED_INITSIM3 7 // Initialising modem
>> #define NET_LED_COPS 6 // COPS initialisation
>> #define NET_LED_NETINIT 5 // GPRS NET initialisation
>> #define NET_LED_NETAPNOK 4 // GPRS APN is OK, final init
>> #define NET_LED_NETCALL 3 // GPRS Network call
>> #define NET_LED_READY 2 // READY state
>> #define NET_LED_READYGPRS 1 // READY GPRS state
>> The normal behavior is it will start at 10 green blinks and count
>> down to 2 (GSM only) or 1 (GPRS). If GPRS lock is lost, but GSM
>> is still up, the green will blink 1.
>> The followed error codes are defined:
>> // LED ERRORS
>> #define NET_LED_ERRLOSTSIG 1 // Lost signal
>> #define NET_LED_ERRMODEM 2 // Problem communicating
>> with modem
>> #define NET_LED_ERRSIM1 3 // SIM is not
>> inserted/detected
>> #define NET_LED_ERRSIM2 4 // PIN lock on the SIM
>> #define NET_LED_ERRCOPS 6 // COPS GSM lock could not
>> be obtained
>> #define NET_LED_ERRGPRSRETRY 7 // Error (maybe temp)
>> during GPRS init
>> #define NET_LED_ERRGPRSFAIL 8 // GPRS NET INIT failed
>> The error code is cleared (red led turned off) once everything is ok.
Stegen Electronics
Kwartslaan 95
3162 RD Rhoon
The Netherlands
Tel: +31 10-5016960
www.stegen.com
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120515/f0c0f4d3/attachment-0001.html>
