[Ovmsdev] Cool down
Thu Jun 28 09:40:05 HKT 2012
I've been experimenting with cool down, but can't get it to work as I expect. For example, here are the results for a recent charge:
7:15pm - Ambient: 30ºC, PEM: 37ºC, MOTOR: 54ºC, BATTERY: 39ºC, SOC: 74%, IDEAL: 230km. Arrived home and plugged in (timer delayed charge, so nothing happens).
7:28pm - Ambient: 30ºC, PEM: 38ºC, MOTOR: 53ºC, BATTERY: 39ºC, SOC: 74%, IDEAL: 230km. Action: Force charge at 220V 10A.
7:33pm - Ambient: 30ºC, PEM: 45ºC, MOTOR: 51ºC, BATTERY: 39ºC, SOC: 74%, IDEAL: 230km. Still charging 220V 10A.
7:42pm - Ambient: 30ºC, PEM: 45ºC, MOTOR: 47ºC, BATTERY: 39ºC, SOC: 75%, IDEAL: 232km. Still charging 220V 10A.
7:58pm - Ambient: 30ºC, PEM: 45ºC, MOTOR: 43ºC, BATTERY: 39ºC, SOC: 75%, IDEAL: 235km. Still charging 220V 10A.
7:59pm - Ambient: 30ºC, PEM: 45ºC, MOTOR: 43ºC, BATTERY: 39ºC, SOC: 75%, IDEAL: 235km. Action: Increase charge current to 220V 24A.
8:48pm - Ambient: 34ºC, PEM: 47ºC, MOTOR: 39ºC, BATTERY: 34ºC, SOC: 82%, IDEAL: 256km. Still charging 220V 24A.
8:49pm - Ambient: 34ºC, PEM: 47ºC, MOTOR: 39ºC, BATTERY: 34ºC, SOC: 82%, IDEAL: 256km. Action: Increase charge current to 220V 48A.
9:03pm - Ambient: 34ºC, PEM: 53ºC, MOTOR: 39ºC, BATTERY: 33ºC, SOC: 86%, IDEAL: 267km. Still charging 220V 48A.
9:18pm - Ambient: 33ºC, PEM: 53ºC, MOTOR: 39ºC, BATTERY: 33ºC, SOC: 90%, IDEAL: 283km. Still charging 220V 48A.
10:19pm - Ambient: 30ºC, PEM: 41ºC, MOTOR: 38ºC, BATTERY: 33ºC, SOC: 95%, IDEAL: 299km. Charge had completed (some minutes early) and car was sleeping.
Some comments:
There was no appreciable change to the battery temperature (@39ºC) when slow-charging at 220V 10A.
Increasing charge rate to 220V 24A did seem to bring down battery temperature (@34ºC).
Increase in ambient temperature when charging @24A is most likely due to the car being in the garage, and aircon dumping charging heat raising ambient temperature in the garage.
Between 7:28pm and 7:59pm, charging @10A, the charger put 5pm ideal miles into the car, +7ºC on the ESS, but zero change to battery temperature.
Is the battery @39ºC not hot enough for cool down to matter?
Anyone know the default thresholds for Tattler, or anyone doing this manually and seen any affect?
P.S. I'll try to drive a little more spirited, with the aircon off and performance mode engaged, on the drive home tonight, to see if I can bring up the temperatures to make the affect more pronounced. Forecast is for 33ºC ambient, and it'll be hotter than that in the city.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120628/d6cc5fb7/attachment.htm>
