[Ovmsdev] OVMS Hardware v2.0
William Petefish william.petefish at gmail.com
Tue Jun 12 07:22:04 HKT 2012
I don't think that the rasbrrypi will work. The controller/sbc has to have
CAN bus.
William
On Mon, Jun 11, 2012 at 5:57 PM, Pierre Uhl <pi.uhl at bluewin.ch> wrote:
> What about Rasberrypi?****
> http://www.raspberrypi.org/faqs****
> Regards****
> Pierre****
> *Von:* **ovmsdev-bounces at lists.teslaclub.hk** [mailto:**
> ovmsdev-bounces at lists.teslaclub.hk**] *Im Auftrag von *Mark Webb-Johnson
> *Gesendet:* Montag, 11. Juni 2012 06:56
> *An:* OVMS Developers
> *Betreff:* Re: [Ovmsdev] OVMS Hardware v2.0****
> To keep this simple, let's split the requirements into two:****
>    1. Cheap, simple, just do one function (remote monitoring and control)
>    Budget: Around US$100 end-user price
>    Requirements here are:****
>     - Compatibility with OVMS v1firmware****
>       - GPS as well as the current GPRS****
>       - Easier to manufacture, QC and support****
>       - Monitoring of the 12V line****
>    1. Kitchen sink
>    Budget: tba, but probably in the US$200-US$300 range
>     - Linux base (incompatible with OVMS v1 firmware, so will need a port)
>       - As low power consumption as possible****
>       - Wifi as a client****
>       - Wifi as a car hotspot****
>       - Optional little 3.5" - 5" touch display, in a housing, to go up
>       on the dashboard****
> With the exception of the multi-can requirement, those seem to meet
> everyone's needs.****
> Irrespective of what happens with [2], I still think we need [1]. That is
> the base requirement to get OVMS in a car, and needs to be as cheap and
> simple as possible.****
> The big question is, does anyone see a need for [2] (the kitchen sink)?
> (if necessary, trying to put aside that you already have [1])****
> For me personally, doing development on this, I really like the idea of
> [2], and would be willing to spend the money. To be able to directly ssh to
> the car and get access to the can bus would be extremely useful for
> development, and firmware updates could be done over the air (either GPRS
> cellular or WIFI). I have lousy cellular coverage at home, and the car
> being able to switch to wifi would be really useful.****
> Regards, Mark.****
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120611/78ad4f22/attachment.htm>
