[Ovmsdev] Issue #61
Bennett Leeds
bennettleeds at gmail.com
Tue Jun 26 23:08:03 HKT 2012
The manual does need to be updated, but I think it's a great idea. It'll be
quick to revise - I'll do it tonight.
- Bennett
On Tue, Jun 26, 2012 at 7:50 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
> I've made a small revision to the firmware for upcoming 1.3.1.
> https://github.com/markwj/Open-Vehicle-Monitoring-System/issues/61
> For the MODULE, SERVER and GPRS SMS commands, rather than just replying
> "Parameters set...", reply with the detailed setting (MODULE?, SERVER?,
> GPRS?).
> It seems to work nicely and gives you a good confirmation of the setting
> that you just changed. This is instead of the old "Parameters set..."
> message.
> P.S. Bennett: Not sure if the manual needs to be updated to reflect this -
> can you check? Or, is this a bad idea?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120626/4a705712/attachment.html>
