[Ovmsdev] Issue #61
Tue Jun 26 22:50:38 HKT 2012
I've made a small revision to the firmware for upcoming 1.3.1.
https://github.com/markwj/Open-Vehicle-Monitoring-System/issues/61
For the MODULE, SERVER and GPRS SMS commands, rather than just replying "Parameters set...", reply with the detailed setting (MODULE?, SERVER?, GPRS?).
It seems to work nicely and gives you a good confirmation of the setting that you just changed. This is instead of the old "Parameters set..." message.
P.S. Bennett: Not sure if the manual needs to be updated to reflect this - can you check? Or, is this a bad idea?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120626/42efb24a/attachment-0001.html>
