[Ovmsdev] OVMS v2 Simple Hardware
Sun Jul 22 17:56:38 HKT 2012
Guys,
Here are the latest pics. Very neat, and getting close.
This was supposed to be the final prototype, but some problems found:
1. Diag port can't tx while pic on. This is caused by the new voltage divider arrangement, and we're trying to add a diode to get it working.
2. 12v ADC measuring circuit doesn't work. Design issue, now ok.
3. GSM/GPRS switch stuck ON. Board design fault, now ok.
Other than that, it works perfectly. Can bus is fine, LEDs are the same brightness and easy to read. Transistor circuit for async comms pic->sitcom works great (thanks William). Cable arrangement is fantastic.
So, I've got a final prototype board coming in the next week or so. I'll run that in my car for 1 week, and if no issues are found will then give production go ahead.
Color samples: I've chosen C-65, but seriously considered C-15 or C-75.
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120722/35fe7916/attachment-0002.png>
DIAG port and LEDs.
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120722/35fe7916/attachment-0010.jpe>
Car connector, gsm and gps antennas.
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120722/35fe7916/attachment-0011.jpe>
Compare vs v1. Under 1/2 size, overall.
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120722/35fe7916/attachment-0012.jpe>
Board slides out.
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120722/35fe7916/attachment-0013.jpe>
Cable and size comparison.
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120722/35fe7916/attachment-0014.jpe>
