[Ovmsdev] little problem/feature needed/debug
William Petefish william.petefish at gmail.com
Sat Feb 18 00:05:50 HKT 2012
Problem confirmed still. Module doesn't seem to be responding even after
the reboot request.
Another popped up, pin entry in app limited to 2 characters.
William
On Feb 17, 2012 8:34 AM, "William Petefish" <william.petefish at gmail.com>
wrote:
> Mark,
> Will Do.
> Waiting on it now.
> I'll run a test after I get out of my first class.
> William
> On Fri, Feb 17, 2012 at 8:25 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
>> Michael,
>> I just tried from the iPhone App I'm working on, and all seems ok.
>>    - Car was not charging, standard mode with limit 13A on a 70A HPC.
>>    - I sent a charge mode command to RANGE mode, and car switched to
>>    range mode, started charging at 13A and reported charging,range.
>>    - I sent a charge mode command to STANDARD mode, and car switched to
>>    standard mode, while charge continued at 13A and reported as
>>    charging,standard.
>>    - I sent a charge limit command to 32A, then car sent back limit 32A
>>    and within a few seconds increased the current at the car to 32amp.
>>    - I sent a charge limit command to 70A, then car sent back limit
>>    70amp and within a few seconds increased the current at the car to 70amp.
>> Sonny says he has fixed the Android App charge mode and the version in
>> the market should be ok now. Can you try that?
>> If the new version has not yet been released, perhaps selecting
>> performance mode will enter range mode (assuming 3=2 and 4=3)?
>> On 17 Feb, 2012, at 9:35 PM, Mark Webb-Johnson wrote:
>> Michael,
>> I tried issuing the commands manually on the can bus and can switch modes
>> shown on the VDS.
>> N.B. There is a bug in the Android App on the marketplace - it gets the
>> mode numbers wrong (I guess 0..3 not 0,1,3,4).
>> I'm implementing this in the iPhone App tonight, so should be able to
>> test later.
>> On 17 Feb, 2012, at 9:11 PM, Michael Stegen wrote:
>>  I can confirm that switching between charge modes does not work 100%.
>> I tried switching to range mode, and then start charging from the app.
>> The battery indicator in the car changes, i.e. the top of the battery is
>> visible.
>> Range does not change, also charge mode visible on the VDS does not
>> change (still standard charging)
>> On the (Android) app , it's shows the same. After i stopped the charging,
>> i received a SMS that does not start with Range - or Standard -
>> just "Charging Stopped, ideal range ..etc"
>> Tonight i'll try to send the commands manually on the CAN bus, to see if
>> i see any difference in behaviour.
>> Btw, i do receive a "Hello World" push message on my android phone, but
>> not on the Ipad.
>> I'm not using any testflight version anymore, but the one from the
>> appstore.
>> Btw2, when a charge is stopped, i used to receive a push message + SMS,
>> this somehow does not work anymore for me. I only receive the SMS
>> Btw3, the car powers up fine, and starts charging, even if left unused
>> (but connected) for over a day.
>> -Michael
>> Op 17-2-2012 8:06, Mark Webb-Johnson schreef:
>>   P.S. Could someone fix the display so it reads Range Mode instead of
>> Standard Mode when switched from standard to range? (Much appreciated.)
>>  Is this Android App?
>>  If so, Sonny (again): modes are 0=standard,
>> 1=storage,3=range,4=performance
>>  P.S. What happened to mode 2? Did there used to be a mystery fifth mode?
>>  On 17 Feb 2012, at 2:59 PM, William Petefish wrote:
>>  Mark,
>>  Yes, fully repeatable, reproducible, and verifiable.
>>  When not woken up first, none of the commands work.
>>  I will restart the module and try further.
>>  It will disarm the alarm and allow it to be driven.
>>  William
>> On Fri, Feb 17, 2012 at 12:51 AM, Mark Webb-Johnson <
>> mark at webb-johnson.net> wrote:
>>> William,
>>>  Is it repeatable?
>>>  ie; plug in, stop charge. wait 5 minutes until coolant pump turns off,
>>> then try start charge from the app.
>>>  Also, are other commands working (like lock/unlock)?
>>>  After setting the feature for write-enabled CAN bus, you need to
>>> restart the module. If not, none of the commands will work. If at least one
>>> of the commands is working, then that is fine.
>>>  Regards, Mark.
>>>  P.S. Not wishing to hijack this thread, but since you are in the USA -
>>> could you test the lock/unlock commands for us on your US car? Supposedly,
>>> the US cars don't have an immobiliser so that the UNLOCK command will
>>> disable the alarm and allow the car to be driven. Please try and let us
>>> know.
>>>   On 17 Feb 2012, at 2:35 PM, William Petefish wrote:
>>>  Mark,
>>>  Yes, I did and to no avail. I had purposefully let the car sit until it
>>> went into power save mode and tried again, no joy.
>>>  Might it have something to do with the new FW on the roadster? (4.6.4
>>> I think is the FW that is on mine.) My roadster is a 2.5.
>>>  William
>>> On Fri, Feb 17, 2012 at 12:29 AM, Mark Webb-Johnson <
>>>> William:
>>>>  Current (1.2.0-rc3) code is:
>>>>   void can_tx_setchargecurrent(unsigned char current)
>>>>   while (TXB0CONbits.TXREQ) {} // Loop until TX is done
>>>>   TXB0CON = 0;
>>>>   TXB0SIDL = 0b01000000; // Setup 0x102
>>>>   TXB0SIDH = 0b00100000; // Setup 0x102
>>>>   TXB0D0 = 0x05;
>>>>   TXB0D1 = 0x02;
>>>>   TXB0D2 = 0x00;
>>>>   TXB0D3 = 0x00;
>>>>   TXB0D4 = current;
>>>>   TXB0D5 = 0x00;
>>>>    TXB0D6 = 0x00;
>>>>   TXB0D7 = 0x00;
>>>>   TXB0DLC = 0b00001000; // data length (8)
>>>>   TXB0CON = 0b00001000; // mark for transmission
>>>>    can_tx_wakeup(); // Also, wakeup the car if necessary
>>>>  void can_tx_wakeup(void)
>>>>    TXB0CON = 0;
>>>>   TXB0D0 = 0x0a;
>>>>   TXB0DLC = 0b00000001; // data length (8)
>>>>  That should work. Pre-rc3, I used to see this, but since rc3 it has
>>>> been ok for me.
>>>>  Maybe the bus was busy and lost the wakeup message? Did you try
>>>> sending any other commands, or repeating the start charge command?
>>>>  What is the version of your car (2.x or 1.5?).
>>>>  Regards, Mark.
>>>>  P.S. There is also a specific command C,18 that calls the CAN wakeup
>>>> function. Not sure if the Android App supports it or not.
>>>>   On 17 Feb 2012, at 2:22 PM, William Petefish wrote:
>>>> Mark,
>>>>  Feature Needed: Wake Up command.
>>>>  I tried to send the start charge command from my android phone and it
>>>> wouldn't start to charge or change charging mode, etc. without being woken
>>>> up by opening/closing the doors/trunk/remote/etc.
>>>>  I am using the latest release (1.20) and the Android app.
>>>>  William
>>>> OvmsDev mailing list
>> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>> Stegen Electronics
>> Kwartslaan 95
>> 3162 RD Rhoon
>> The Netherlands
>> Tel: +31 10-5016960www.stegen.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120217/d494fd40/attachment.htm>
